HELP! thread gage removal
Likes Likes:  0
Results 1 to 15 of 15
    Mar 2011
    Twin Cities, MN, USA
    23
    Question HELP! thread gage removal
    I've been given the task of calibrating some of the Thread Gages at the shop where I work. I'm having trouble trying to remove the GO thread from a double-sided thread gage (pic1).
    Normally on this type of handle, the tapered end of a special drift-punch (pic2) is used to remove the GO thread, then the reverse side of the punch us used for removal of th NO-GO thread.
    My problem is that the back end of the GO thread doesn't extend into the handle far enough for the drift punch to hit it (pic3). Any suggestions?
    Thanks in advance,
    TheInspector
    Jan 2007
    Norfolk, UK
    18,698
    14229
    14249
    Drop a small ball bearing in through the side hole to take up the distance,* insert drift and hit
    *A little grease will hold it in place.
    Dec 2010
    Tyler, Texas USA
    342
    15
    29
    +1 on the BB. Used that trick a number of times. It will sit in the grinding center on the gage member ok with a spot of grease.
    Dec 2009
    657
    498
    446
    Same thing I'd suggest x2
    Dec 2000
    Bremerton WA USA
    10,671
    40
    4223
    The handle is aluminum. Dip it in 300 degree F hot oil. Expansion of alum Vs Steel will release the plug.
    Dec 2010
    Tyler, Texas USA
    342
    15
    29
    Before I learned of the BB trick, I just set them under an incandescent light for a while.
    Forrest's hot oil reminded me. Hot oil would certainly be quicker.
    Mar 2011
    23
    Quote Originally Posted by Tony Wells View Post
    suggestions on type of grease? we have about 50 different types here. (or does it even matter, as long as it's semi-sticky?
    Dec 2010
    Tyler, Texas USA
    342
    15
    29
    The grease is entirely uncritical except for it's sticktion.
    Mar 2011
    Denver, CO USA
    10,215
    58
    5696
    A brief visit with a torch, I use that to remove collets from my little mill, works every time...I keep a Benzomatic handy for that purpose.
    Mar 2011
    23
    Default sticktion
    Sticktion is a word now. we should all add it to Wikipedia as follows:
    sticktion (adj); the ability of a given product to make something stick.
    see also: coefficient of friction
  11. #11
    Dec 2010
    Tyler, Texas USA
    342
    15
    29
    Opposite of lubricity, maybe? Or would it be Teflonicity?
  12. #12
    Jul 2005
    Newcastle, Australia
    595
    136
    Note that "stiction" (sic) is already in use;
    Stiction - Wikipedia, the free encyclopedia
  13. #13
    Mar 2011
    23
    Lightbulb Solution
    so, i was unable to find a ball-bearing of the proper size that I could pound on, but I cut the short end of an allen wrench down and used it in a similar way. no time for pics, sorry.
    thanks for the suggestions, guys.
  14. #14
    Mar 2011
    23
    Thumbs up insufficient
    Quote Originally Posted by plannerpower View Post
    sweet coincidence, but the existing definition is insufficient.
    we all need to add an additional one.
  15. #15
    Dec 2010
    Tyler, Texas USA
    342
    15
    29
    Slightly different word. Static + friction is stiction. It's more fun to make a new one for grease. Anyway.....don't get too serious here.
    Inspector...you got the late shift, eh? Glad you found something that worked.
