Help with trouble shooting my bridgeport mill
Results 1 to 17 of 17
    Sep 2018
    Default Help with trouble shooting my bridgeport mill
    Im atill a beginner by all means! Just got a job at a shop that has old machinery. Im having trouble woth cutting my keyways on my mill though! Ive swept in my vice and everything but my keyway cuts are riding off to the side. Can anyone lead me in the direction of finding and fixing my problem because i am the only machinist in this whole shop
    May 2017
    Massachusetts
    385
    419
    194
    Maybe backlash in the axis you're cutting along is allowing the cutter to push the part (and the table) off in one direction due to tool pressure?
    Have you locked down the axis you're not traversing during the cut?
    Just one possibility.
  3. Likes Richard King liked this post
    Dec 2015
    Illinois
    483
    176
    270
    Are the 2 bolts holding the ram (on the right back side of the machine) tight. I had all kind of weird things happening one time until I realized that someone had loosened them.
  5. Likes Richard King liked this post
  6. #4
    Apr 2004
    Modesto, CA USA
    7,516
    1318
    Are you taking to deep a cut and trying to cut the slot in one pass?
  7. #5
    Mar 2005
    Indiana
    4,789
    1265
    1212
    Don't try to cut keyways with an on-size endmill in one go. Use a smaller one to rough out the keyway, then either move it side to side and make passes to finish size (generally preferred if you want properly straight and correctly sized keyways) or swap for an on-size endmill and run it down the roughed out keyway.
  8. #6
    Nov 2015
    400
    150
    Lower likelihood, but sweep your part or vise jaw with the part clamped in. I stumbled across a vise cracked at the fixed jaw key on a BP several years ago. The vise indicated fine open, but the fixed jaw would bend back on one side when something was clamped near the top. Shop manager insisted that it wasn't fully broken and therefore didn't need to be replaced.
  9. #7
    Sep 2009
    Phoenix,AZ
    1,862
    2871
    485
    And what are you using for a cutter? 2 flute works the best. And as said lock all axis not in use including the quill if it is retracked.
  10. Likes Richard King liked this post
  11. #8
    Apr 2009
    Beaver County Alb. Canada
    1,889
    544
    928
    How are you holding the endmill ?
  12. Likes JohnEvans, MetalCarnage liked this post
  13. #9
    Dec 2010
    Uruguay
    91
    28
    I use a very old worn-out Bridgeport to cut my keyways, mostly 3/16ths wide and as long as needed using a 3/16th wide woodruff cutter. This may or may not work for you depending on the size of the keyways you cut and on the diameter of the shaft.
  14. #10
    Dec 2008
    New York
    10,359
    2688
    most rough out keyway 1/64 to 1/32 small and then take a finish cut. all cutters deflect under load. usually dont use a 1/4" end mill to cut a 1/4" keyway or if you do you finish taking a very small amount
  15. #11
    May 2003
    Iowa
    10,490
    3616
    4281
    I know that this will come as a surprise, but there is a Bridgeport forum.
    Pictures. There are so many things that you could be doing wrong, with out pictures or being there, everybody is just guessing.
    JR
  16. #12
    Jan 2006
    Angier, North Carolina
    2,622
    1125
    993
    I'm sorry you are having trouble shooting your Bridgeport, but honestly, it is not that hard - just point the gun and pull the trigger!
    (Don't you just love helpful answers like these??)
  17. #13
    May 2007
    2,599
    3054
    479
    Check your vise and make sure it has zero indicator runout on immovable jaw and be sure to tighten the vise down good sonyour vise does not move. I assume your head moving forward and backward tilt is secured from moving as is the nuts on the boom and swivel. Also on your head rotation left to right on x axis.
    Be sure your bed ways are not severely worn as they can move. For this some people snug the bolts which secure movement on the x and y axis snug it to drag making it tighter. If you are slotting in the X direction lock your way saddle in Y tight to not move.
    get a solid tool holder if you can and lock your quill so it does not move. Feed into the slot at a shallower depth to see what happens before going to depth. Also use first a scrap piece of comparable steel and cut that rather than a finished shaft to avoid scrap.
    test it out first on raw material not finished lathe parts.
    hope this helps.
  18. #14
    Oct 2010
    Maryland- USA
    4,267
    2172
    2644
    Are you closing your eyes when you pull the trigger?
  19. #15
    Virginia
    31,413
    7561
    9863
    Quote Originally Posted by Trboatworks View Post
    If he was not "warned off" by the Bridgeport brand? Surely had to have had his eyes wide-shut!
  20. #16
    Jul 2005
    Cottage Grove, MN 55016
    7,874
    4204
    4676
    I private messaged this newcomer to listen to JR who is a very good Moderator IMHO.
    also found this for him. CUTTING A STRAIGHT KEYWAY with BRIDGEPORT MILL tubalcain - YouTube
    You smart Alecks need to remember you were once new to the trade and had to write your first post here. He came to ask us for help not get a bad time.
  21. #17
    Virginia
    31,413
    7561
    9863
    Quote Originally Posted by Richard King View Post
    Yah well.. crusty Old Farts may have hurt my sensitive feelings when I was a youngster and still owned any such of a thing.
    But the MONEY they saved and years of life not wasted was one Helluva useful PAYBACK for it.
    His own situation. His own call. His own "due diligence" what or whom to pay attention to.
    Or not.
    No "bad time" involved. Just different experiences, shared-out. In PUBLIC, even.
    Not "back-doored".
