Help troubleshooting Pump for ball mill sin exchange for FREE CHOCOLATE!
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Jun 2019
    Default Help troubleshooting Pump for ball mill sin exchange for FREE CHOCOLATE!
    Hello to all on the forum
    This may not be the correct place to post this, so if anyone has advice on a better location, I would really appreciate the help.
    My problem is with the ball mill that grinds chocolate from the roasted beans. There is a pump at the base that cycles the chocolate through and returns it to a spout at the top to reincorporate with the rest. The pump should be activated until the beans and sugar have ground up enough to flow. At this stage its basically a viscous suspension of melted fat and small solids like sugar.
    The problem is that even with the pump off a small but continuous trickle of chocolate comes out of the spout. My first thought was that the shaft of the pump was still turning through some fault, either electrical or mechanical however I have verified several times that it is not turning even in the slightest. The fact that the chocolate is still passing through and going straight up a pipe WELL ABOVE th level of the chocolate in the mill is something that I cant get my head around. Im attaching photos to help, but if anyone knows what this is, I'll gladly send you out some chocolate.
  2. Likes Screwmachine liked this post
  3. #2
    Sep 2015
    Ohio
    1,030
    595
    1002
    Total shot in the dark, but maybe a clog or one of the braided lines collapsed inside and while the pump is pumping everything flows fine but when the pump shuts off the residual pressure behind the clog keeps oozing?
    Aug 2005
    Raymond , CA
    210
    137
    If there was air mixed in with the melt it would tend to expand at the first opportunity and force the melt out of the spout. I see what appears to be a pneumatic operated ball valve below the spout. It is the box shaped gadget with the red hat in the second picture. Is the valve closing when the pump cycle is complete?
    The return pipe also has a water or steam jacket. Is there a steam leak in the jacket that may be forcing the melt out?
    I would also expect that there would be some process which blows out and empties the return pipe at the end of the work shift to prepare the grinder for cleaning. The problem may be that the PLC controller is confused and is instructing the grinder to clear the pipe.
    Nov 2018
    Michigan
    196
    88
    106
    I'm inclined to hitch my wagon to Robert's guesses above. Have you noted how long the undesired flow persists after the pump is shut off? If it is reasonably finite and consistent I would think that something may be purging the line with some kind of pneumatic pressure.
    It may even be leftover pressure in the system. 80 psi is about 5.5 atm, so in order to equalize after everything is shut off, 5x the volume of air on the "process" side of the valve will need to go somewhere. Path of least resistance is spitting a little extra chocolate out of the spout. In this case it would taper off very slowly and probably never completely purge the line. You might notice significant burbling on start-up of the next batch.
    Mar 2005
    Kansas
    7,347
    419
    3350
    My guess is the ball mill is actually forcing the choclate through the pump. How about a pic inside the ball mill next time you get it cleaned up.
  7. Likes Limy Sami, snowman, awake, Hightemp liked this post
  8. #6
    Jul 2014
    Ontario, Canada
    1,019
    728
    656
    Quote Originally Posted by gbent View Post
    My thinking as well. The rotation of the mill is causing hydrodynamic pressure of the viscous fluid, causing it to be pumped up the return pipe.
  9. #7
    Jan 2007
    Norfolk, UK
    18,336
    13865
    13845
    That was my first thought, + any air pockets in the system would compress and ''squeeze'' the choccy out of the pipe after the pump is off.
    Please, no nuts in my choccy, (the bits get caught under my denture plate) raisins are good, cherries even better
  10. Likes camscan liked this post
  11. #8
    Nov 2018
    Michigan
    196
    88
    106
    Seems easy enough to test the two prevailing hypotheses:
    1. If it's a positive displacement pump, it would not allow fluid to be forced through it without shaft rotation. Otherwise, the mill itself could be pushing chocolate around.
    2. If the flow tapers off and eventually stops, it could be pressurized air pockets expanding after shutoff.
    Keep us updated, I'm interested to hear about what you end up finding. No need for sweets, I just think it's an interesting puzzle.
  12. #9
    Jan 2007
    Norfolk, UK
    18,336
    13865
    13845
    Quote Originally Posted by BoxcarPete View Post
    Can I have Boxcar Petes sweets then?
  13. #10
    Aug 2005
    Tucson AZ
    6,235
    9181
    2923
    I don't see anything there that I recognize as a ball mill. I don't see how it could grind or produce any flow. Could you give more details on this
  14. #11
    Aug 2015
    Illinois
    1,317
    943
    554
    And information on the pump, please.
  15. #12
    Aug 2005
    Raymond , CA
    210
    137
    The chocolate ball mill machines, judging from a duckduckgo search all seem to be made in Europe or Asia.
    The Packint mill is made in Italy. Their website is :About Us | PACKINT
    This is a example of a major manufacturer's product line: Chocolate Processing - Royal Duyvis Wiener B.V.
    The OP's grinder is a small machine. The grinder uses a high pressure pump for the viscous melt. It appears to be a gear pump. The small machines have a three way ball valve. The valve allows recirculation of the melt during the grind phase and then directs the melt to a holding tank using a transfer line when it is time to empty the grinder. The 3 way valve is placed at the base of the grinder on other designs to allow the vat and return pipe to be emptied.
    The OP's grinder has the valve at the top of the vat. The return pipe continues past the spout and the three way valve to a higher elevation for the transfer line. This feature is cut off from the top of the picture.
    The transfer line is acting as a stand pipe and would cause the unintended spout flow if the valve leaks.
    The ball mill design consists of a central vertical shaft driven by a motor -speed reducer set. The vertical shaft has a number of radial arms extending outward. At the end of each arm there is a pocket which holds one grinding ball. The ball rolling against the side of the vat grinds the chocolate and sugar to 30 micron size particles. The taste of the chocolate is strongly dependent on the grinding operation. This grinding process is followed by a tempering process which cools the liquid and forms crystals. This insures that the chocolate will become a stable solid.
  16. #13
    May 2003
    Lambertville, MI USA
    2,519
    1053
    1117
    How about this. The chocolate is very viscous and when you turn the pump off it takes a while for it to run out of the spout. This isn't water.
  17. Likes Limy Sami liked this post
  18. #14
    Norfolk England
    1,935
    2332
    1432
    Quote Originally Posted by Limy Sami View Post
    Perhaps you should read some posts from just over a year ago. They were all about some bloke having a heart attack,might curb your cravings a tad.
  19. #15
    Jul 2010
    Joliet Il
    82
    26
    30
    OP's in California; the machine is missing its Prop65 warning label, that's the problem. #needmorelawyers.
  20. #16
    Jan 2007
    Norfolk, UK
    18,336
    13865
    13845
    Quote Originally Posted by camscan View Post
    Do you want another week without YOUR sweetie ration?
  21. Likes camscan liked this post
  22. #17
    Norfolk England
    1,935
    2332
    1432
    Blimey,that takes me back a few years,sweets on ration. No coupons,no sweets.
  23. #18
    Jan 2007
    Florida
    1,088
    132
    400
    sweets don't do at all well with beer!
  24. Likes Booze Daily liked this post
  25. #19
    Mar 2001
    Switzerland
    2,504
    2213
    1069
    Quote Originally Posted by Keyepitts View Post
    I just bid on some collets on the bay and they list a Prop65 warning, and they're in Iowa! I remembered reading about it here (I'm in Switzerland). They we're probably made in the 60s.
  26. #20
    Jan 2007
    Norfolk, UK
    18,336
    13865
    13845
    Quote Originally Posted by cg285 View Post
    I no longer drink alcohol - mores the pity
