Help w/ Warner Swasey #3
Results 1 to 15 of 15
    Jan 2014
    Knoxville, TN
    79
    Default Help w/ Warner Swasey #3
    We have a warner swasey #3 that bogs down quite a bit when you take a cut. Even with a small cut like .02 it loses umph. At low rpm, itll almost stop the chuck. Now ive ran these machines all my life. Seems like any ive run in the past have had power for days. Can anybody tell me whats going on?
    May 2002
    South Central PA
    13,456
    2178
    3394
    If the clutch is not slipping, is there any chance it's a 440 volt machine running on 220?
  3. Likes Philabuster, timvercoe liked this post
    Jan 2014
    Knoxville, TN
    79
    Clutch doesnt sound like its slipping but i can look at that
    Jan 2014
    Knoxville, TN
    79
    Box on the back of the machine say 240. Cant see whats on the motor. Its plugged into 208. I dont know whats going on with it.
    Nov 2015
    589
    25
    226
    Did it ever work properly, or is this a new-to-you or recently moved machine?
    Jan 2007
    Norfolk, UK
    18,617
    14159
    14162
    A phase down?
    Apr 2009
    Beaver County Alb. Canada
    1,843
    532
    906
    Running in reverse with a dull tool. LOL
    Check your motor and or clutch! As others have stated.
  9. Likes JRIowa liked this post
  10. #8
    Apr 2006
    Manchester, England
    8,131
    1164
    5107
    Vee belts slipping/broken ?
    Regards Tyrone.
  11. #9
    Mar 2013
    Missouri
    1,841
    1285
    1002
    our #5 can hit .5 doc without bowing down. you definitely have a problem.
    is this a war machine? or is it a hydraulic machine made later on?
    This could be as easy as a dated piece of electrical gone bad or a clutch.
    You need to find out if the motor is slowing down when you take a cut.
  12. #10
    Jul 2004
    Southeast Michigan
    6,547
    239
    1450
    Did you engage it fully? The amount of travel of the engagement arm is directly proportional to the amount of force on the clutch.
  13. #11
    Dec 2004
    uk
    14,057
    4552
    6699
    Of the top of my head voltage is roughly squared to hp on a induction motor, ie half the voltage, you quarter the delivered HP. A thick gear oil and a headstock full of gears will happily eat a couple of hp to start with too so it can have a surprisingly big effect even on a 10+hp machine
  14. #12
    Jan 2014
    Knoxville, TN
    79
    We just bought it at auction and it has been recently moved.
  15. #13
    Apr 2006
    Manchester, England
    8,131
    1164
    5107
    You need to check out the drive train then. Start with the motor and work your way through it.
    Regards Tyrone.
  16. Likes Limy Sami liked this post
  17. #14
    Nov 2009
    Michigan USA
    1,102
    81
    231
    when bogging down does the main motor bog down? There are clutches at the feed levers too.
  18. #15
    May 2003
    Iowa
    10,492
    3616
    4269
    Quote Originally Posted by p4th4ss View Post
    If it's a newer square head machine, you could have hydraulic problems. The best around for fixing W&S stuff is Gahr. They ain't cheap to have come in, but they know their stuff.
    Gahr Machine Company. - Home Page
    JR
  19. Likes upthebikes, digger doug liked this post
