LiquidMetal
- Nov 29, 2016
- Silicon Valley
Long story, please be patient.
I bought a No. 1 Sjogren Speed Chuck by Hardinge Bros. at a local yard sale. Great deal. It is well used, but in excellent condition.
I mounted it on my lathe (a Chinese model, NOT THE PROBLEM here). I bought a D1-6 adapter plate and machined the alignment boss to match the collet chuck and drilled and tapped the mounting holes. My runout on the adapter plate is about 0.2 - 0.3 thou, which is good for my lathe.
For final collet chuck testing, I used a 1/2" hardened dowel pin in the collet chuck. My runout on the dowel pin is 0.010. Yikes. I cannot tap it into alignment. There is no way to adjust the runout of the collet chuck that I can see.
I have only three options that I can see:
1. Enlarge the four mounting holes on the collet chuck so I can move it a little when mounting. I Do not like this method. I don't want to modify the collet chuck.
2. Turn down the heads and upper shanks of the mounting screws (3/8" SHCS) to allow the chuck to move a little for alignment, then tighten it down.
3. Turn down the alignment boss so the chuck is held only by the four screws. Hope there is enough room in the chuck screw holes to tap into alignment before tightening.
Is there a better approach?
Any help is appreciated.
Thanks much,
LM
Thanks much,
LM
