Erichimedes
- Mar 20, 2019
Help with Wells Index milling machine 887: Head noise
I'm looking at a mill close by to me (that never happens) and it's got a couple small issues I'd like to run by you guys and see if anyone has some good information for me.
The mill is a Wells Index 887 with variable speed head.. Pretty rare bird as far as I can tell. The only difference I can figure from the 847 is that the table is bigger, at 12 x 50. As far as I know, the head is the same as a variable speed 747 or 847. The ways are in halfway decent shape, which is 99% of what I care about, but the head has two issues that I know I'll need to dive into. Anyone who has experience with these mills; I'd love your input!
#1. When you put the machine into high speed and run it, there's a pretty solid knocking sound coming from the upper part of the head between the drive pulley and the top of the spindle. If you push UP on the high/low shift lever, the sound almost totally goes away. From what I understand, when you shift the lever up (high speed) it disengages back gear and engages some sort of dogs for direct drive. To me, it sounds like those dogs are what's rattling. Does this sound possible? And if so, does anyone know if replacing worn drive dogs is a huge task?
#2. The quill power down feed lever on the front of the head won't engage. If you push it up, it seems like it's trying to make the quill move, but not much. It also doesn't STAY up, it just springs back down again. I know these heads have an adjustable clutch for the power quill feed, and to me, it seems like that clutch needs to be adjusted. But I don't know why it won't stay engaged, any thoughts?
Pics of the mill attached. 2nd pic shows the high-low shift lever, and 3rd pic shows the front of the head, where the power quill feed lever is.
Thank you!
Thank you!
