I'm looking for a good beginner spinning lathe. I'm in Colorado USA. I used one*back in college (8years ago) to make a few bowls. Any guidance on what I*Should get and where. I'm thinking I would like one That could do up to an 8-10inch*disc. In college I was using 6inch copper disc out of 18 gauge sheet.
For the project I would like to do I would like to be able to do copper, aluminum, silver, and maybe bronze.
I know a silversmith that spins, and he spun me a set of sterling sake cups a few years ago.
He has 2 lathes, one was converted to a motor, but was originally run by line shaft. The other is a tad newer, but may have had a motor on it originally.
Both of his lathes are Pryibils. They were made around the turn of the 1900s in NY. The lathe is only one piece of the puzzle, you need useful tooling to make it really useful, but you can make much of it yourself given some patience and time.
They pop up on ebay from time to time, but asking price is always pretty high. Here's one that is listed at the moment in PA.
3 " Pryibil metal spinning lathe with 31 tools | eBay
The asking price is typically between $5k-$10k. I've watched some sit for months. I don't think people will pay that for them.
Other people convert a normal lathe and build up the tool post. The tool post is the biggest issue, as it need to be solid because the burnishing tools used for shaping need a very solid post because they free float like woodworking lathe tool posts work.
One thing I would consider if I was wanting to spin would be to remove the compound entirely and replace it with a solid mounting tool post. You would get more rigidity by eliminating the compound.
Here's the website to my friend that spins. If you look under his studio page you'll see some pics of the Pryibil he uses. I believe he got the lathe from his mentor, Porter Blanchard, when he died. Silversmithing is a dying art, in the traditional sense, and not a lot of spinning going on, but Randy does do it and I have, err...my wife has a pair of sake cups to prove it.
Randy Stromsoe
