DocsMachine
Titanium
- Jan 8, 2005
- Southcentral, AK
Simple question with, I'm sure, a not-so-simple answer: What sort of issues might I face using cutting oil, rather than water-based coolant, in a small VMC with a 10K RPM spindle?
Parts are small, aluminum, relatively low complexity, and only moderate accuracy.
Part of the reason for using the oil is the machine will only be used a limited number of hours per month. I'm not a high-volume shop (yet) and I figure the thing will only see 10-20 total hours of use a month.
Oil eliminates evaporation issues, smell/rancidity, rust, and the need to frequently adjust concentrations.
On the other hand, I know it's nowhere near as good as a coolant, and heat issues may be a problem.
Is there anything else of significance I should know about? Reduced tool life? Reduced surface finish?
And, now, for the real heresy.
I've been using Mobilmet 426 cutting oil in my other machines (including a CNC lathe) and it appears to be working fine. But, being in Alaska, a single bucket costs me $260 including shipping.
I can get hydraulic oil locally for less than $70 a bucket. I know that's probably false economy, but just for the sake of the argument, what would be different about it as a cutting oil? I read about guys being able to tell when their soluble coolants get off-spec for concentration, and can tell the difference between brands.
One would presume the cheap hydraulic oil wouldn't have the proper additives to make a good cutting oil, but I guess the question is, how bad would it be? Chip welding? Insert breakage? Endmills lasting less than ten minutes?
Doc.
Doc.
