Hello,
I need to cut a 1/2" hex hole in mild steel to join a part to a shaft. I understand that the proper way to do this would be broaching. These broaches are quite expensive so I was wondering if anyone had input on how to make a broach. I was thinking of following a similar procedure to Clickspring in his broach making video.
The problem is that I can't find 1/2" hex tool steel. Would hardening mild steel work to cut mild steel? I only need the broach to last 1 hole.
Any other ideas on how to accomplish this?
