HEY Facing and Centering machine question
Likes Likes:  0
Results 1 to 11 of 11
    Nov 2006
    Montco, PA
    556
    46
    68
    Default HEY Facing and Centering machine question
    I need to take a 1.5" steel rounds and turn chamfers on each end. One end needs to have the OD cleaned up by about 4" long
    Would the HEY machines be able to do this?
    I can do this on a CNC lathe but am looking for a faster solution.
    I see that they can face and center drill......just not sure if there is someway to turn the OD to clean up all while keeping the end chamfers running true.
    Oct 2005
    17,782
    You can look at adjustable hollow mills, they should be able to, but the 4"
    deep might cause vibration problems
    Genesee Manufacturing
    You could make up your own "double knee tool" like used in a turret (make it double to balance it )
    BTW are you O.K. with retract lines on the O.D. ?
    Oct 2005
    17,782
    How long are the pieces ?
    No center drilling ?
    Maybe have someone like Ox set up a acme multi to bang these out from barstock.
    Apr 2018
    4,229
    1912
    Hey and Giddings & Lewis Fraser both made these. One used facemill-type cutters to set length and the other used big mills that just plunged to depth. I think the Hey was plunge-to-depth, but don't rely on that. Pretty sure I have seen examples of chamfering the ends of parts in the same operation as center-drilling but 4" is kind of long.
    If you are doing enough pieces it's definitely worthwhile but both machines are expensive. They are also pretty big, so if you are doing small parts, not so great. I guess most job shops just blunder through using conventional tools but the good part of a double-end facing and centering machine is that you know the centers are in line. Not so easy if you do it end-for-end.
    btw, this would be a perfect job for an old H40 Cincy, which so many people claim are worthless junk that should be scrapped. Last I looked a small (and they are not really small) Hey was ten grand, while an H40 that can do all kinds of dumb jobs like this might bring $500.
    Nov 2006
    Montco, PA
    556
    46
    68
    The pieces are 25" long. No center drilling needed. Retract lines on the OD are ok too. Its just a gripping surface for another operation.
    Nov 2006
    Montco, PA
    556
    46
    68
    Those are interesting........
    Apr 2018
    4,229
    1912
    Quote Originally Posted by G-Auto View Post
    I bet you could do that lickety-split in an OAB Warner Swasey, and for cheap cheap. Very automated, a $2 guy could do it. The 4" length is no problem either.
    All you have to do is find one now
    Mar 2005
    Indiana
    4,770
    1260
    1199
    Quote Originally Posted by EmanuelGoldstein View Post
    We had those centering machines but hardly ever used them. With larger shafts just stuck them in v-blocks on a turntable on an HBM and faced and centered both ends. With smaller ones just used a center head to roughly mark center, then either hand drilled with a small center drill, or alternatively a small pilot hole and banged a big center punch in, then stuffed a center in the end and cut spots for a roller rest and faced and centered both ends. If the spots weren't round a quick zip with a center reamer and re-cutting them took care of that.
    Easy to get them inline that way - not that it really matters much. By the time you rough out a big shaft the centers won't be perfectly inline anymore anyway due to movement in the material. Got to re-cut them before finishing.
    Oct 2005
    17,782
    Yabutt the 25" length is.
    I'm not standing in front of mine stuffing parts into it.
    My point was to bar feed them, un-attended.
    Now that the 25" overall length has come out (in post #5 ...), the dynamics have changed.
    FWIW my friend modified a swiss to feed out to maybe 16", removed the secondary tooling, replaced with a "catcher tube", and does similar work on 1/4" dia. steel stock.
    So maybe a brownie could be picked up cheap and hacked up.
    What was that job Ox posted a video, loading cylinder rods into/out of an acme 2 years ago ?
    Feb 2007
    Aberdeen, UK
    3,912
    1389
    1587
    The G&L ones run a facemill across the end of the bar for sure. I've been looking for a bigger one for a few years now but they rarely come up and seem to demand a hefty price when the do.
    I haven't seen a Hey type.
  11. #11
    Apr 2018
    4,229
    1912
    Well, yeah, but if he using an nc lathe to do this he'd have to stand there was well. And it wouldn't be as reliable ...
    You could probably make a simple parts feeder or maybe precut then stack them inline thru the bar feeder with a liner ? but it'd make an ungodly clunk when they fell in the chip pan
    Quote Originally Posted by eKretz View Post
    Definitely production machines, you wouldn't go to all the hassle of setting them up for just a few parts. Plus they cost big bucks
    I had a little hand-driven single-ender for a while, forget who made it, but by then nc machines came along and it was easier to face the end, put a center in then run the tailstock up than it was to pre-machine the blanks. So I never used it as much as I thought, either.
