HF Blasting Cabinet, Metering Valve installed, having issues....
Results 1 to 8 of 8
    Feb 2012
    Columbus, Ohio
    38
    Default HF Blasting Cabinet, Metering Valve installed, having issues....
    Well I'm working on my new HF Blasting Cabinet. I made my own metering valve, it works ok, but it still surges, and clogs a little. I feel I need to increase the air flow to decrease vacuum maybe not sure, the supply hose is very full. I will post pictures soon.
    Thank you.
    Sep 2006
    SW Wisconsin
    585
    58
    159
    Let the blasting begin!!
    Ed.
  3. Likes jamscal, Rudd liked this post
    Mar 2005
    Indiana
    4,894
    1316
    1258
    Quote Originally Posted by atex57 View Post
    Ed.
    Ohhhh, I see what you did there...
    May 2019
    GUADELOUPE
    975
    342
    465
    Syphon style blasters suck, save your self the trouble and get a pressure pot style.
    Aug 2004
    Virginia
    2,515
    186
    1019
    Make sure the sand in a siphon feed system is exceedingly dry or it will surge and clog.
    Dec 2012
    AUSTRALIA
    3,007
    12
    976
    Yep ,dry ...and water blown along in the air stream will cause blocks too...........Think yourself lucky you arent using steel grit .....some places all the steel grit has to be shovelled out every night and stored in airtight containers ,or it will be a solid mass of rust next morning....And a shovel full of grit is like 100lb.
    Feb 2010
    IN, USA
    260
    7
    277
    Maybe you spent too much money. Have you looked into a cheaper one?
  9. Likes digger doug, eKretz, Rudd, atex57, Newman109 and 1 others liked this post
  10. #8
    Jun 2015
    Minnesota
    559
    11
    196
    He must be using a pressure pot. I've never heard of a metering valve on a siphon feed. It's hard enough getting enough grit to begin with, Hardly need to meter it. The only metering you need on a siphon feed is using the right size nozzle matched to the ability of your air compressor.
    Those cheapy pressure pots work okay. A quality steel ball valve is about ll you need to meter the grit. Even till the valve will start leaking soon enough, so you have to turn of the grit valve immediately after stopping to load more parts or take a piss. If you don't your hose will fill up with grit and you're screwed. Then you have to remove the nozzle and blow the hose clean of grit.
    Unless you're blasting off only a fine layer of corrosion, you must screen the grit every time before putting it back in. The adjustment on the grit valve can be all over the park. It all depends on how big of a hurry you're in or how often you feel like stopping to reload the tank. The sound you want is a mild hissy sound. Too hissy and you're not feeding enough grit. The sound will go kind of quiet if you're feeding too much. Somewhere in the middle is what you want. Dry air is a must. 5HP minimum even on those cheapy pressure pots. Honestly... 5HP minimum for any half serious blasting. And I mean half serious.Wearing out a 10 horse is not that hard either.
    The OP mentioned surging. I've had that happen some time ago. Can't for the life of me remember what caused it. A leak somewhere? Wet media? Not enough pressure?
