Cal Haines
- Sep 19, 2002
- Tucson, AZ
I'm trying to find a good reference that relates the strength of a thread to percent thread depth and the length of the thread. I intuitively know that if I increase the tap drill size beyond some point the threads get weaker, but if I increase the number of threads that are engaged the joint will be stronger and at some point the larger tap drill won't matter. But I have not found a good reference to back me up.
On page 1924 of my Machinery's Handbook (27th ed.), under the heading "Diameter of Tap Drill", they make the statement:
For 1/4-20, my handy-dandy Starrett reference card calls for a #7 (0.201") tap drill, which is 91% thread depth. A #2 (0.221”) tap drill gives a 54% thread depth, with a lot less effort required to tap and less chance of tap breakage.
At present, I'm dealing with 1/4-20 by 0.50" thread depth hole in 6061-T6. How big can I make the tap drill without sacrificing strength, assuming 0.50" thread engagement? Anyone know of any good references or on-line calculators to answer this sort of question?
Cal
"Tests have shown that any increase in the percentage of full thread over 60 per cent does not significantly increase the strength of the thread. Often, a 55 to 60 per cent thread is satisfactory, although 75 per cent threads are commonly used to provide an extra margin of safety."
However, the table that immediately follows, Recommended Hole Size Limits Before Tapping Unified Threads, lists min and max hole sizes for various lengths of thread engagements. For 1/4-20 threads less than 1/3 diameter long (< .083"), the table calls for 87 to 100% thread depth. For thread lengths from 1½ to 3 diameters long (.375 to .750"), they call for 75 to 85%. I haven't checked any other sizes, but they don't seem to be following their own 60% rule.For 1/4-20, my handy-dandy Starrett reference card calls for a #7 (0.201") tap drill, which is 91% thread depth. A #2 (0.221”) tap drill gives a 54% thread depth, with a lot less effort required to tap and less chance of tap breakage.
Cal
