High speed parting blades--why?
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 106
    Dec 2008
    W. Mich
    357
    103
    143
    Default High speed parting blades--why?
    New tooling comes and goes but I don't remember anything as revolutionary as the carbide insert style parting tools. I was a former user of the HSS blade for parting, when I used it I developed what I call the HSS parting tool grimace, a squinting, puckered up facial expression in anticipation of what inevitably is bound to happen. Then my brother, who worked 2nd shift in a shop doing cut-off on 2 1/2" steel bars with an Iscar carbide insert style parting system, said as an experiment, he increased the feed on the lathe one step at a time to see where it would fail. He was amazed how fast he was feeding with still perfect results. Finally it broke either the insert or the blade, I forget which. He insisted I buy this type, which I did and never looked back. If anyone is still using the HSS blade for parting do yourself a big favor and give the insert blade a try, possibly the best tooling advance I have ever seen. If you are confidently using a HSS blade with good results, you are to be admired as an elite machinist! Thoughts?
    Mar 2012
    Geilenkirchen, Germany
    2,563
    1510
    1304
    Quote Originally Posted by Bluechipx View Post
    I am happy for your success, but my experience is exactly opposite. Yes, they initially cut wonderfully, but the edges fail very easily (chip) forcing a new insert to be installed and they are very expensive. I have a HSS blade on a Phase II holder that is more than 10 years old and doing fine. I have resharpened it maybe 6 times. I am very experienced with cut off tools and I have used the carbide insert tool holder on 2 large very stiff lathes in like new condition.
  3. Likes thomj liked this post
    May 2019
    Michigan
    1,479
    426
    677
    +1 for the carbide insert blades, especially Iscar. Their Tang-grip with the L shaped insert is pretty hard to beat.
    Dec 2008
    W. Mich
    357
    103
    143
    Quote Originally Posted by steve-l View Post
    The carbide insert system for cut off has a unique top geometry the forms a chip narrower than the groove, if you are successful with a HSS blade you must have a certain way of sharpening the tip that makes it work for you. My congratulations on that, one question though, do you use power feed when parting? It's still hard for me to imagine a person using HSS with a calm, relaxed look on their face when doing it!
    May 2019
    Michigan
    1,479
    426
    677
    I remember reading Tom Lipton's book Metalworking Sink or Swim where he was talking about parting on a manual lathe.
    Quote,"If you're scared of parting, watch a CNC lathe do it. It's too dumb to be scared." Very true!
    Also, I have had bad experiences with cheapo cutoff systems. I had a Hertel one time that was worse than HSS.
    Aug 2004
    Virginia
    2,468
    179
    980
    I use an HSS parting blade and get good results. When I first started out I used hand feeding thinking I would have more "control" over the cut. I found this to be the exact opposite. If the tool is ground and sharpened properly it works much better for me with power feed.
  8. Likes JohnEvans, sfriedberg, thomj, M.B. Naegle liked this post
  9. #7
    Oct 2005
    17,788
    Your really coming off as a carbide salesman with this line.
    Your new here, read the archives, the HSS/Carbide/Ceramic debate has several
    threads over the years.
    Brand new HSS cut off blades are still being made & sold every day, there is a market
    for it.
  10. Likes Steven-Canada liked this post
  11. #8
    Apr 2004
    Modesto, CA USA
    7,490
    1311
    I use a small chainsaw sharpening stone parrallel to the long axis to put a slight dip on the top of the hss blade. I think this rolls the chip to be narrower then the cut. I seldom part and, for me, the last tiny bit is the hardest. I think that I probably need to go to crazy high rpm to get the sfm needed.
    Bill D
  12. Likes CalG liked this post
  13. #9
    Apr 2004
    Modesto, CA USA
    7,490
    1311
    I suppose they can be ground for a special thickness for grooving or a special tip shape. You do not have to part with the tool.
    Bil lD
  14. #10
    Mar 2012
    2,563
    1510
    1304
    I never use power feed when parting. I like to feel the cut as it progresses. That way if a chip bind starts to occur, I can back off and clear the cut immediately. One hand on the infeed and the other on the oil brush.
  15. Likes challenger liked this post
  16. #11
    Feb 2007
    St. George, Utah
    1,051
    596
    696
    Quote Originally Posted by Bill D View Post
    Bil lD
    Right on, Bill! I have both, and often grind HSS for O-ring grooves, snap-rings etc. Yes, I could grind carbide too but parting inserts are pricey.
  17. Likes steve-l liked this post
  18. #12
    Mar 2012
    2,563
    1510
    1304
    I'm sure everyone has their own system, but I like blade holders that use a slight positive angle. On my L&S I use a straight blade holder, both work well for me. I use 7 degrees rake when sharpening and I NEVER grind the top of the blade. It is unnecessary. Cut off operations are very much a feel thing for me. It is necessary to get exactly the correct tool load. Too light is bad and too heavy is as well, but there is a window when the tool load is perfect and it is a feel thing to find it. The tricky part is that every material is different. That is why I never use power feed.
  19. #13
    May 2019
    Michigan
    1,479
    426
    677
    for it.
    No, Doug. He's not a spammer. a bit adventurous maybe (giant bottle rockets ), but not a spammer.
    That Chinese spammer must be making you trigger happy.
  20. #14
    Oct 2005
    17,788
    Quote Originally Posted by ChipSplitter View Post
    I know that, I said that the "first line" in his post looked suspect.
    I even colored it RED for illustration.
  21. #15
    Dec 2008
    W. Mich
    357
    103
    143
    Here's a good question, has anyone ever needed the insane fastest feed on bigger lathes? I think that it should be standard on lathes to have a 'creeper' speed. So many times I do an operation that the slowest feed is still to much. I put a gear in the initial drive that reduces the feed by exactly half, and I need it often. Of course when threading you have to remember to double the pitch. My Axelson will do .300" per revolution, fastest and .004" slowest, still too fast for many operations.
  22. Likes Steven-Canada liked this post
  23. #16
    Jul 2019
    Florida
    1,434
    1398
    282
    HSS holds up to shock very well and it properly sharpened with good coolant flow does well. They last a long time and repeatedly they can be sharpened. They are great on a manual lathe. CNC usually will use carbide.
    Like drills and end Mills it is the case with drills people prefer HSS because carbide can shatter and it often destroys the part. I have seen one shop which valued carbide highly. They were largely very successful with it. It was funny when the manual guy would cut material always preferring carbide he could break a few because he cut it way too hard. No biggie yet on manual I hate when carbide shatters. Just me.
  24. #17
    May 2005
    Interior British Columbia
    2,469
    261
    788
    Thoughts?
    Yeah, I gots thoughts. Mine are that yer doing it wrong if it scares you, or isn't working.
    Power feed cutoff ROCKS! And it's kinda cool when you got a chip pan covered in little coins of coiled up chip, too.
    HSS, carbide, whatever. Just different flavors of the same thing. Each has it's place.
    If you can't get HSS parting tools to work for you, eventually, you will really hate buying inserts and parting tool blades, as the seat for the tool inevitably gets mangled by a blown up insert at near zero surface speed.
  25. Likes Trueturning, wheels17, Rudd liked this post
  26. #18
    Sep 2010
    Oklahoma City, OK
    4,957
    887
    2072
    I'm the opposite. I think the power feed's smooth, steady pressure provides a better cutting environment than my shaky hands.
  27. Likes jhruska, JohnEvans, Mcgyver, newtonsapple liked this post
  28. #19
    Feb 2005
    Owl's Head, Maine
    2,324
    394
    638
    I switched over, happily, to using Aloris carbide wedge-lock parting blades in an Aloris holder, except for the rare cases when, not so happily, a really narrow blade must be used or when a small mushy workpiece needs the scary sharp edge of HSS.
    And I agree about using manual infeed to find the sweet spot for the revs/material used. Machine feed I can see for a production run when parameters have been determined.
    -Marty-
  29. Likes Trueturning liked this post
  30. #20
    Feb 2010
    ch
    2,498
    215
    329
    i always wished for slower feed, even on the drill press.
