RollinEEZZ
- Apr 4, 2020
Need a small drill press for the shop ... need to stay under $1000.
Largest holes will be 1/2" drilled through 3" steel pipe (3-1/2" OD, .216 wall thickness) ... and mind you this will be done infrequently.
More commonly will be drilling through 1/4" thick aluminum.
Seriously considering this machine:
17" JET 16-Speed Floor Mount Woodworking Drill Press, 3/4 HP, speed range 210-3500 RPM, Model# 716300
JET(R) 17" Floor Standing Drill Press - 16 Speed, 3/4HP | JET(R) Woodworking Machines
It's marketed as a woodworking drill press but think it can handle our needs and prices out at $850.
Will this machine handle listed needs? - or are there better recommendations around the same price?
