Hey so the title sums it up pretty well. I have a quote where I need to hold +0 -.0002” on a roughly .875” bore 1.5” deep. Material is 316 stainless
I’ve been able to hold these tolerances on external features but internal features may be a little harder. Qty on the parts is low about 25parts quarterly.
should also mention the machine positions to .00001”
I was thinking 5/8 solid carbide bar for semi finish Would let me hold a few tenths but to inure I hit that +-.0001” I was consider other options.
Internal grinding is one option but the part has almost no way to be refixtured to go on to my cylindrical grinder and I don’t have a high rpm internal head either way.
I did consider grinding on the machine. It has a 12k spindle only though and for the 1/2 or maybe 5/8 stone required I don’t see that really being optimal.
Next thought was finishing to within a few tenths on the lathe then setting up a hone of some sort. But trouble with this comes in the form of no space to setup a sunnen hone although I do see them for sale every few months and also absolutely no experience at all with honing and whether I can even hold those tolerances on a hone. I have drill press I could stick a hone in?
Parts will be checked with a 3point digital bore mic checked against a master ring gauge. I may also pick up a .0001” bore gauge for some additional gauging.
So that’s my thoughts. I know there are some folks that hit these tolerances all day on the forum.
What do you guys recommend?
