Hole punch angles
Likes Likes:  0
Results 1 to 6 of 6
    May 2009
    Canandaigua, NY, USA
    2,887
    141
    1290
    Default Hole punch angles
    I often find myself making hole punches for things like gaskets and paper templates. Are there any generally accepted angles for sharpening that both cut well and hold up well?
    edit- I'm talking cork borer type punches, not matched plug and hole punches.
    Oct 2010
    Oregon
    5,110
    4392
    1854
    When I made some punches to cut rings from felt, I used roughly 40 degrees included angle. It's my impression that C.S. Osbourne arch punches have an included angle more like 25 degrees, when the internal taper is taken into consideration, but I do not have one handy to put a protractor to.
    May 2009
    2,887
    141
    1290
    Thanks. Surprised not more replies. I have some import punches that have what appears to be a huge included angle, yet they work fairly well. I usually have no internal taper, just an angle on the OD.
    Oct 2005
    15,557
    I would look for angles used on steel rule dies.
    Jun 2001
    St Louis
    18,020
    1886
    3037
    I have a large set of arch punches to an inch or more diameter. Most seem to have soemthing between 30 and 45 degrees included angle per side. it can be hard to measure or estimate the angle on small surfaces.
    Oct 2013
    st,louis mo
    673
    349
    I made a quick set years ago . Long alan screws,cut of the heads,center drilled unthreaded body.They have served me well. So to answer your question,60 included angle or 30 degrees per side. Good luck Edwin Dirnbeck
