MichaelP
Titanium
- Dec 7, 2008
- IL/WI border
I'd like to know the general approach to holes and threads management in parts to be heat hardened.
The steels of interest are: W1, O1, A2, D2, S7, 4140.
What happens to holes, internal and external threads after heat treatment? Do all the above mentioned steels display the same behavior (for example, do holes in all of them become smaller after heat treatment)? Yes, I know that W1 and O1 are much worse in terms or distortion than A2 or D2, but is the dimentional change goes to the same direction?
Do you have any issue with not protecting the threads (other than wrapping parts on foil or using atmospheric control furnace)?
Do you routinely use oversized taps or undersized dies if hardening will be done? How much of a dimentional change can you expect in holes from, let's say, .125 up to about .750"? How do you handle routine press fit situations? I understand that grinding and lapping are options for certain cases, but how often do you really do in routine press fit tasks with hardening?
Thank you for sharing your knowledge and hands on experience.
Mike
Mike
