Hot roll laminator - roll refurbishing
Results 1 to 16 of 16
    Jan 2011
    Estonia
    702
    188
    Default Hot roll laminator - roll refurbishing
    Hello !
    We use hot-roll laminators here and during use the hot roll gets scratched
    Similar rollers:
    New, Used and Refurbished Lamination Rollers– VitechParts
    I dont know exact material, its medium-hard rubber-like with surface working temp about 120deg Celsius
    How can the surface be reworked, we need to remove about 0.5..1mm
    Dont want to scrap used rollers as the replacement is 1000 bucks a piece..
    Any advice ?
    Jan 2011
    Estonia
    702
    188
    I rephrase my question in easier form
    How can I make round smooth rubber roll ? Turning or grinding ?
    Please help
    Jun 2012
    Michigan
    4,591
    4202
    2756
    Quote Originally Posted by Madis Reivik View Post
    Please help
    I would suggest turning. Not grinding.
    Maybe sanding?
    Dec 2008
    minnesota
    153
    26
    161
    Wet grinding is
    the method that works on rubber rolls.
    Feb 2014
    Sunny South West Florida, USA
    2,700
    10331
    3119
    .040" of rubber off an unknown durometer roll across 30"...
    I guess if someone told me I HAD to do it, and the job would repeat enough to justify the time/effort, I'd try to source/make a box tool and use a SUPER sharp cutting tool, either an upsharp aluminum insert with a tiny nose radius, or a hand ground piece of HSS (I'm no great shakes at grinding HSS, but I think I could handle this)...
    If you're unfamiliar with box tools (I was until they were mentioned here on PM), this should give you some ideas. Obviously you'd need it radially mounted instead of axially, so that you could traverse the entire length of the part.
    lathe box tool - Google Search
    Dec 2008
    IL/WI border
    3,184
    1002
    922
    I suspect that freezing of the roller prior to machining may help. I've done it long ago when I needed to turn rubber parts occasionally (surface finish wasn't critical though).
    P.S. I imagine liquid nitrogen as a flood coolant would be nice to try.
  7. Likes Lewie liked this post
    Feb 2006
    so cal, usa
    581
    201
    141
    I work for a packaging company, and we have rubber covered rolls made / recovered all the time. The rubber guy just dry grinds the rolls to size.
  9. #8
    Jan 2011
    Estonia
    702
    188
    Quote Originally Posted by greggv View Post
    How and what ? Please give more info !! tnx !
  10. #9
    Jan 2005
    The Netherlands
    5,693
    262
    1425
    I had great succes with sanding
    We did it on a lathe with a beltsander with a aluminium wheel on the lathe
    Peter
  11. #10
    Oct 2009
    Oregon
    4,088
    4386
    2054
    Rubber/poly is ground, not turned.
    You guys thinking you're going to turn it are in for a hell of a fight.
    I would send it off to those that specialize in it, but if I had to do it I'd mount a heavy belt grinder to a lathe and go to town.
    About a year ago I was at an auction and was trying to figure out what the hell one of the lots was. I took to long and they had a no sale on it with $1000 minimum. Turned out it was everything to strip, prep, rubberise and grind rolls to about 30' long.
  12. #11
    Mar 2010
    Davidson NC USA
    1,420
    511
    808
    The mystery in rubber rolls is the selection of the proper compound and the required Shore durometer needed to do the job. To do your job correctly, the ideal is an adequate lathe and a tool post grinder to fit your size roll. Feeds, grits, and type of bond in the wheel will divulge the right recipe. A compound-mount slack belt grinder will also work, depending on the final finish you need. Be careful of excess feed or bite, which may cause reversion of the rubber, (big mess). Keep the roll clean with a mild solvent between passes. You can't go wrong by finding a roll shop that knows how to do it. You might ask the manufacturer of the equipment.
  13. #12
    Jul 2005
    central Illinois
    228
    1171
    81
    I second the suggestion of using a tool post grinder on the lathe. We used to often grind 9 ft. long rubber covered rollers for a local plastic bag factory and had no problem grinding them dry.
    Went into it plenty ignorant of such processes and used the wheel that happened to be mounted on the grinder at the time as an experiment, worked a treat, so we get no credit for any wheel selection, just dumb luck.
    Had the feed rate rather slow, I do remember that, if old man memory serves, it took ~1/2 hour for a pass and we never had to make 2 passes. I'd certainly share speeds and feeds if I remembered the facts, but I do not any longer.
    Prepare for the mess, might kill off a shop vac if you have lots to do, but worth it. We used to kind of joke we should just forklift the lathe outside for those jobs, but it was a beast of a lathe and wish I'd never sold it.
  14. #13
    Jan 2011
    Estonia
    702
    188
    I have the shore-meter nearby, i try to measure the hardness.
    So, a good bet would be cyl grinder with coarse open aluminium-oxide wheel ? Since I have to buy the wheel, share opinions about grit size.
    I can use coolant but is it better try ?
    P.S. I locate in Estonia, so there is no "roller refurbishing shop" available nearby and in Finland or Sweden, the attitude and price is awkward...
    P.S.S. One old Soviet era anecdote - a man goes to local shop in Tallinn (capital of Estonia). "Excuse me, where can I get needles from sewing machine? " hmmm "from Helsinki I guess".
    The irony is that although there were no sewing machine needles or bananas or meat in Tallinn in Soviet occupation, there were facilities that worked with pure tungsten or inconel details 4meters in diameter.
  15. Likes sfriedberg liked this post
  16. #14
    Jan 2005
    The Netherlands
    5,693
    262
    1425
    I worked in a spinning mill for a while And they had thousands of rubber rollers
    When these were worn they had a centerless grinder with a drum that had emery cloth wrapped around it as a grinding wheel
    Worked like a charm
    Thats why I came up with a belt grinder And I have practised it several times
    Peter
  17. #15
    Mar 2006
    jacksonville,fl.
    1,072
    911
    352
    I occasionally grind rubber and polyurethane rolls with a TP grinder using a 36Grit induced porosity wheel (or also known as a "bubble wheel").Also made a wheel guard that has a vac cleaner hose attachment.
    Have to play with the doc and feed depending on material, wheel and power available.
    Generally start with .002"DOC and feed 1/4 wheel width per revolution and go up or down from there.
    If I have a lot of material to remove I use a carbide tooth saw blade to rough cut as you can take a lot deeper cut but obviously a lot less feed.
  18. #16
    Dec 2008
    IL/WI border
    3,184
    1002
    922
    Quote Originally Posted by ratbldr427 View Post
    ...feed 1/4 wheel width per revolution...
    What rubber roller diameters and lathe chuck rpms are involved in your case? What kind of surface finish do you get on rubber using this method?
    Do you have the manufacturer's name/ product## of the wheels you suggested?
    Thank you.
