Finegrain
- Sep 6, 2007
- Seattle, Washington
So I have this part that is ~12" long and has a couple reamed holes ~11.5" apart, +/-.002" on the hole spacing. The shop is at 55F this morning. I do the math, 24 millionths per *K per inch, and I figure the thermal change will be .00199", perilously close to the tolerance. Then I got to thinking, wouldn't the machine itself also be affected? Granted it is iron and steel, so would not change as much, but still, it seems like the machine components would also be smaller on a cold day. This is a 2016 Brother Speedio S700X1.
Not talking about thermal comp settings in the control BTW. I get that as the machine heats up the control can compensate for expansion.
What do you think?
Regards.
Mike
What do you think?
Regards.
Mike
