borne2fly
Hot Rolled
- Feb 7, 2008
- California
All three bearings are a light press fit into the housing, and a light press fit onto the shaft. To put it back together, it would seem like I first need to press each bearing onto the shaft one at a time (pressing on the inner races), then press the whole thing into the housing. But how is the second part done without some of the bearings getting pressed into the housing via the shaft? At that point I'd like to apply pressure only to the outer races, but it seems you'd need to do all three simultaneously. Is there some special assembly trick for this sort of thing? This is the input shaft from an old L&S lathe. Someone suggested I heat up the housing with a torch, but that headstock is a massive thing and I can't believe the factory did that. Any ideas?
