How to best Chuck a narrow gear
Likes Likes:  0
Results 1 to 7 of 7
    May 2020
    SWEDEN
    5
    Default How to best Chuck a narrow gear
    I bought myself some gears that were missing for my lathe. They are too wide so i have faced them down to correct width, 10mm a little bit less than 1/2 inch. They come machined with a fixing "grip" approx 25mm or 1 inch on one side so this was not any problem. Now i have to turn the gear arround and part off this "fixing grip part" and i do not get it how to fix the now narrow 10mm gear in my 3jaw chuck to get it true...?
    Any ideas for this would be appriciated.
    Jan 2002
    West Coast, USA
    8,442
    570
    5964
    Machinable collet is one solution. If your lathe takes 5C collets, I like and use the "JFK" type with a steel 5C portion and a replaceable / machinable aluminum bit in sizes up to 4" or so. If all you have is a 3 jaw chuck, you could machine up your own sort of collet out of a bit of aluminum round stock to hold around the gear teeth while you face off the nub. Mill, of course, another option. The gear wouldn't care if you cleaned up the face with something like an abrasive belt or disk.
    Mar 2017
    233
    104
    MDF faceplate?
    Mount a piece of thick MDF to a faceplate and turn a recess that the gear fits into snugly. Take light cuts.
    I do this when making new clock wheels. After cutting the teeth, cut a fresh recess, snap in wheel and rebore the center. A trick for making sure yer new wheel is concentric.
    Jan 2011
    Michigan
    152
    63
    Quote Originally Posted by Hedghog View Post
    This is essentially a facing operation. Concentricity is not important but parallism is. Make a split ring to fit the od, and use parallels to set the back side then go at it. Facing rather than parting ma be a safer option. Yah, take the parallels out before you flick the switch.
    Jul 2004
    Houston, TX USA
    30,868
    Make yourself a an expanding mandrel on the end of a piece of stock in the lathe - have it fit the bore, and have a shoulder for the back face of the gear to sit against. Hack saw lots after tapping with small taper pipe type = expanding mandrel once you screw in a pipe plug
    Mar 2006
    jacksonville,fl.
    1,277
    1126
    429
    I have to do a lot of that kind of stuff.Sometimes as Johnoder says.But nothing is as simple as turning up a press fit arbor.A -.0005" to -.001" fit is all you need to face that.Heat to drop on and to remove with no stress.
    Feb 2010
    ch
    2,494
    215
    329
    if you have several then mandrel as above. you can thread it straight and modify a screw to expand it.
    the press fit arbor might give him problems if not hardened for a larger number of parts.
