I don't think you'd get good results from a conduit entry punch. The clearance is too large for .025" material, and stainless is real sensitive to clearance.
It would be easier to point you in the right direction if you told what you plan to use to drive the punch and die. If you don't currently have some machine to mount the tooling in, then a unitized punch assembly from Unipunch or Unit Tool would be the cheapest and quickest option. This can be powered via a press brake or a shop press, or even a good sized arbor press. Either company likely stocks the punches and dies with the proper clearance for your material. When everything is considered, such as the punch, die, stripper, die spring, and the frame to carry it all and keep it aligned, the Unipunch type tooling offers a lot of value for the dollar.
