Finegrain
- Sep 6, 2007
- Seattle, Washington
Hi guys,
I just installed a Quincy QP-5. The pump turns on at ~125 PSI and off at ~175 PSI. I'd like to change the low-end to ~75 PSI, to reduce the number of starts per hour. The release valve that turns the pump on doesn't look to be adjustable, it's a tiny plunger valve with no apparent adjustment. I can adjust the high-end pressure no problem, but I want to lower the low-end pressure.
Are there other release valves for different pressures, or is the 125 PSI valve adjustable? I tried shimming the valve farther from the contact tab on the switch but that didn't change the cut-in pressure.
Thanks, and regards.
Mike
Mike
