metalmagpie
Titanium
- May 22, 2006
- Seattle
I have the table from an old small planer. It has tee slots and also a regular grid of 1" holes. This image should give you the idea:
I have rough cleaned the table and the holes. Many of the holes were plugged with chips packed in with dirt. I got all of them clear and ran a split rod with shop cloth wound around it for a makeshift ID brush in and out with a hand drill motor. They are much better, but they are still not clean. I have some 1" ground shaft and it will fit into some of the holes part way with effort, but not all.
I have a mag drill with #2 Morse taper spindle. I had thought of getting a taper shank 1.000" reamer and putting it directly in the spindle of the mag drill. It might be a bit of a problem getting it perfectly aligned, but it seems to me that should clean out all the rust, dings and so on. On second thought, I thought I should buy a tube brush, one of the aggressive kind with steel bristles designed to be run by a machine. Only I can't seem to find just the right product to buy.
I want to be able to put pins in and use them to align parts against in this table's future life as a welding table.
Do you have any ideas as to the best way to clean these 44 holes?
metalmagpie
metalmagpie
