how to clean out 1" holes in old planer table?
Results 1 to 15 of 15
    May 2006
    Seattle
    2,287
    55
    557
    Default how to clean out 1" holes in old planer table?
    I have the table from an old small planer. It has tee slots and also a regular grid of 1" holes. This image should give you the idea:
    I have rough cleaned the table and the holes. Many of the holes were plugged with chips packed in with dirt. I got all of them clear and ran a split rod with shop cloth wound around it for a makeshift ID brush in and out with a hand drill motor. They are much better, but they are still not clean. I have some 1" ground shaft and it will fit into some of the holes part way with effort, but not all.
    I have a mag drill with #2 Morse taper spindle. I had thought of getting a taper shank 1.000" reamer and putting it directly in the spindle of the mag drill. It might be a bit of a problem getting it perfectly aligned, but it seems to me that should clean out all the rust, dings and so on. On second thought, I thought I should buy a tube brush, one of the aggressive kind with steel bristles designed to be run by a machine. Only I can't seem to find just the right product to buy.
    I want to be able to put pins in and use them to align parts against in this table's future life as a welding table.
    Do you have any ideas as to the best way to clean these 44 holes?
    metalmagpie
    Dec 2008
    Vt USA
    8,859
    1454
    3138
    x-o-rust or whatever. Phosphoric acid would work too.
    vinegar and table salt. Boiling lye solution... (hot tank at the local engine rebuilder....a thing of the past)
    Jul 2007
    Missoula Mt
    793
    28
    323
    What do you plan to use the holes for?...Phil
    Aug 2012
    California, Central Coast
    4,968
    2361
    2042
    Quote Originally Posted by Phil in Montana View Post
    Collecting weld spatter is what I think he said.
    Seriously though you can go to a plumbing supply and get round steel brushes for cleaning copper pipe fittings. they would be 7/8" and 1 1/8" for 3/4 and 1" sizes. If its to short to get to the bottom, crimp a piece of small tubing on to it as an extension.
  5. Likes tdmidget, Scottl liked this post
    Oct 2009
    Olympia, Wa
    725
    325
    230
    A reamer seems like it would work, but I probably wouldn't use a nice fresh one unless I got it really cheap.
    Sep 2007
    Woodinville, WA
    1,836
    221
    408
    The crud will destroy a reamer, so yes, some old POS for sure. No need for a mag drill - hand drill and it will self align for the described purpose.
    I'd use use a flex hone brush. I have a carbide versions that would clean those holes up pronto.
  8. Likes Scottl liked this post
  9. #7
    Jun 2007
    Mass
    484
    28
    70
    +1 for the dingle ball brush - and probably a can of WD-40 to keep it clearing
  10. #8
    May 2006
    Seattle
    2,287
    55
    557
    Quote Originally Posted by CalG View Post
    the fluid would run out the bottom of the hole, won't work
  11. #9
    May 2006
    Seattle
    2,287
    55
    557
    I plan to make a bunch of 1x5" pins with tapped holes on each end. These could be placed in a line and a part could be clamped against them. More pins could be placed in a perpendicular line and another part clamped against them. This would very accurately set up a square for welding, for example.
    Anyway, to put pins into for alignment. The tapped holes are to pull them out in case they get really stuck.
    metalmagpie
  12. #10
    Apr 2006
    Manchester, England
    9,007
    1451
    5948
    The welding tables I worked on had a length of bright mild steel bar roughly 1" by 1/2" laid flat and fastened down by cap head screws along the long edge and another length of bar fastened at exactly 90 degrees down the short edge.
    If you wanted to set work up square prior to welding you just butted the work up to the strips.
    Regards Tyrone.
  13. Likes Limy Sami, Gordon Heaton liked this post
  14. #11
    Aug 2004
    Virginia
    2,622
    198
    1109
    I have recently started using rifle and shotgun bore brushes for this sort of thing. Cut the fitting off that connects to the rod and chuck the twisted wire in a hand drill or drill press. They are cheap, available in just about any diameter up to an inch, can be either brass or SS, and are better then a dingle ball in my opinion.
  15. #12
    Jul 2007
    Missoula Mt
    793
    28
    323
    Just use a reamer turning slow in a mag drill, they with self center, use a little cutting oil...no big deal...sure it will ruin the reamer but there cheap on ebay...been there done that more than once...Phil
  16. #13
    Dec 2015
    Illinois
    527
    185
    324
    Seems like a perfect application for a hand reamer. You might be able to get one for free if you have friends with an
    old machine shop. Or this one on Ebay for 40 bucks
    Interstate Hand Reamer 1" Diam Straight Shank 5-7/16" Flute 02210649 | eBay
  17. #14
    Jul 2011
    Navasota / Whitehall Texas
    3,791
    2800
    2159
    After I did this......
    I ran an old hand reamer through the 1 inch holes. Also in the video you can see two white disks in two holes... Those are 1 inch plastic plugs... I was going to get a bunch of them and plug all the holes until I needed one. On this planer the chips can fall through the holes and collect on the bottom part of the table.. From there they fall out the sides all over the floor
  18. #15
    Jun 2012
    Michigan
    12,296
    4153
    4400
    Quote Originally Posted by Blazemaster View Post
    like 5 bucks ...That crud will make quick puke of a good reamer.
    You can ut a saw slit the but end in a piece of round stock a little under 1". then cut strips of abrasive cloth the same lengths to make up to 1" or 1.005. The length of abrasive will hold very close size with each strip cut the same length. A hand drill should be faster than a mag drill. I used to make the wrap about one turn. Nothing fancy.. just a piece of round stock and a tapped hole for a screw made shank. measure the cloth to know the slug diameter.
    One can do very close hold sizing like this..about +-.002.
    To save abrasive you turn the abrasive the other start/end. then tear off an inch and slip in/under..so uaing most all the cloth.
    Ops look like done..keep this in mind for next same job.
    Buck
