How to clean windings of small 3-phase motor, and what bearing type to use
Results 1 to 19 of 19
    GERMANY
    2,979
    1907
    1094
    Default How to clean windings of small 3-phase motor, and what bearing type to use
    I want to refurb and use a small 220/380V 3-phase motor. It's Swiss, 1/2 HP (=400 Watt) and was made for driving an internal grinding spindle via pulleys. The motor dates from the 1960, I would guess.
    I opened it up and discovered two things that need attention. First, someone pumped far too much grease into the bearings. The windings and a lot of the other internal components are covered with a mix of grease and grit.
    Is there a good way to clean out the motor windings? I suspect this is from the days before epoxy was used for potting windings.
    Second topic: the bearings are both toast. They are GMN 6202 without shields. meant to get grease from external grease nipples. Should I replace them with the same type of open bearings? Or metal shield ones? Or rubber seal ones? C0 or C3 clearance? (This motor drives a 250mm/10" diameter flat belt pulley, and does not have belleville washes or some other way to preload the bearings.
    Thank you!
    Aug 2005
    Tucson AZ
    6,453
    9901
    3034
    As you can see, many more bearings are ruined by too much grease than not enough. I would clean the windings with mineral spirits after gently removing what you can by hand. I would not use any stronger solvent than mineral spirits. I would replace the bearings with sealed ones. Tell them it is for an electric motor, supposedly they are better than cheapest crap they are used to peddling on a price basis.
    Dec 2014
    ESTONIA
    62
    34
    10
    I was in the same situation except dust in windings.
    Swiss motor 50 years old,from tool grinder, without axial preload spring washer. I installed C3 metal shield bearings. The grinder has rather strong belt to spindle. Not sure if I did right, but it works.
    Apr 2009
    Beaver County Alb. Canada
    1,879
    542
    924
    Years ago I had a 3 Ph. motor that was full of grease.
    Pressure washed it, sat the parts in front of the wood stove for a few days, brought it to a mototr shop once assembled and they tested it and it was fine. Been using it for years now with no troubles.
  5. Likes Limy Sami, atomarc liked this post
    Jul 2007
    UNITED KINGDOM
    4,999
    2821
    2453
    As the others have said. The insulation is probably varnish (class B) instead of bitumen (class A). Use kerosene/paraffin/mineral spirits to clean the windings. Then use C3 bearings. A good solution is to use metal shielded bearings and to remove the shield on the side where the grease port is.
    Jan 2007
    Norfolk, UK
    19,663
    15104
    15264
    Like others have said - a bucket of kerosene or mineral spirits (NOTHING STRONGER !!) and a paint brush, plenty of soaking and gentle brushing, leave to drain then gently blow off with air and leave to dry.
    Nov 2009
    Massachusetts
    429
    142
    Quote Originally Posted by ballen View Post
    Insulation is very likely glyptal, which is pretty robust stuff.
  9. #8
    Nov 2006
    Camarillo Ca
    510
    34
    117
    I have cleaned many a motor with engine cleaner. Never had a problem>
  10. #9
    Aug 2005
    Tucson AZ
    6,453
    9901
    3034
    Quote Originally Posted by Mark Rand View Post
    Why remove the shield? You shouldn't be greasing it. Remove the grease fitting.
  11. #10
    Feb 2013
    Northern califorina, usa
    283
    86
    We operate more electric motors in our business then most people would believe, that said more then not when we replace motor shaft bearing that had previously been greaseable we go sealed and use best available sealed bearings.
    We have motors out there with sealed bearings pushing 25,000 hours operational time on large motor compressors.
  12. Likes Sachmanram, Paolo_MD liked this post
  13. #11
    Jan 2017
    Nebraska
    37
    15
    I have a 30 hp 3600 rpm motor I use for a rotary phase converter. It runs a 1750 rpm 20 hp motor driving a hydraulic pump for a 60+ ton press.
    It was overgreased and VERY dirty when I got it, so I used Gunk Engine cleaner several times to get the old grease out of the windings. The last time I used Dawn dishsoap and hot water, and rinsed with hot water. I blew out everything I could and left the motor sit in the July sun for a couple days with a small fan blowing through the windings. I checked all the windings with a megger and they all passed easily.
    I replaced the open bearings with sealed bearings and removed the grease zerks. I use this almost every day for the past two years and have had NO issues.
  14. Likes muckalee liked this post
  15. #12
    GERMANY
    2,979
    1907
    1094
    Quote Originally Posted by tdmidget View Post
    Also my thinking, unless someone can convince me otherwise. I think both grease and bearings have improved a lot in 60 years.
  16. #13
    GERMANY
    2,979
    1907
    1094
    Quote Originally Posted by dana gear View Post
    When we replace motor shaft bearing that had previously been greaseable we go sealed and use best available sealed bearings.
    Do you mean rubber full seals or metal shields? I just checked and decent bearings (SKF) with 2RS (rubber shields both sides) are rated over 10k rpm continuous duty. In my case the motor is running at 2800 rpm, so well below that speed.
    Frankly I don't see any decent reason not to close the grease ports and use rubber sealed bearings. It seems like the sensible choice, no?
  17. #14
    May 2006
    Seattle
    2,059
    47
    399
    Many motors have grease ports whose only purpose is to lubricate the bearing races so that they can slide when the rotor gets longer from heat. These motors should never have grease or oil pumped in post-assembly.
    Rubber sealed bearings have some drag, which wastes energy as heat. Buy shielded, not sealed. If you want one side open buy 6202-Z; else buy 6202-ZZ.
    C3 is a good choice.
    metalmagpie
  18. #15
    Mar 2009
    5,586
    103
    1079
    Remove end bells. Set the motor on end with wood blocks. Then use some Mineral Spirits and brush the inside. Let the solution drain into a pan.
    Reverse orientation of motor and brush down again. Keep doing this until clean.
    If you really must use those grease fittings buy rubber sealed bearings and remove the seals on the end bell side. Nothing will leak into the winding compartment again. But it's better to use sealed bearings as is and forget about the grease fittings.
  19. #16
    Aug 2005
    Tucson AZ
    6,453
    9901
    3034
    When a motor is actually intended to be greased due to severe service (automobile shredder comes to mind) the end bells will have 2 plugs or one on the bottom and a fitting on top. To grease this properly the bottom plug is removed and clean grease pumped the top WHILE IT IS TURNING. The dirty grease will come out the bottom. When clean grease comes out the bottom replace both plugs. It will have the correct amount of clean grease. Any normal service will be better off with sealed bearings.
  20. #17
    GERMANY
    2,979
    1907
    1094
    Thanks everyone for the advice and experience. It's been very helpful.
    I washed out the windings today with white spirit. I used a paintbrush, a toothbrush and an acid flux brush. Afterwards I let it drain for a while then blew it off gently with some compressed air. Right now it's sitting with a 40W light bulb inside it, just a bit too hot to touch comfortably. I'll leave it like that for a few days to dry out.
    I've pulled out the brass grease nipples and will turn a couple of brass plugs to block the ports. I've also ordered a pair of SKF explorer 6202 2RS C3 bearings. With the use this will get (tens of hours a year) and the nasty environment (coolant, grinding grit) I think that makes more sense than metal shields. I don't care if a few watts of power are lost to heat in the seals. (The literature I have seen only cautions against this for shaft sizes larger than 30mm or rotation speeds about 3600 rpm. Neither is true here.)
    The front bearing is captured both sides. The rear bearing is a snug sliding fit and the designers left enough clearance that it can move back and forth as the motor warms and cools. I'll be sure to leave a bit of grease in there to help it move back and forth. I think it'll be another sixty years before the next guy has to swap the bearings again.
    Cheers,
    Bruce
  21. Likes Mark Rand liked this post
  22. #18
    Mar 2009
    5,586
    103
    1079
    That shouldn't be done. The fit is supposed to be a little tight. When the motor is to be taken apart a little heat from a torch will allow the bearing fit to loosen
    just enough so that it slides away from the housing.
  23. #19
    GERMANY
    2,979
    1907
    1094
    Quote Originally Posted by rons View Post
    That shouldn't be done. The fit is supposed to be a little tight. When the motor is to be taken apart a little heat from a torch will allow the bearing fit to loosen just enough so that it slides away from the housing.
    In this motor design, the bearings inner races are a snug interference fit on the shaft. (When I put on the replacements, I will put the motor rotor in the deep freeze and heat the bearings to 120C so that they slide together.) On the other hand the bearing outer races are a transition fit in the housing. I was able to pull them out of the housing with hand force. Not heating was/is needed.
    Within the category of transition fit they are somewhere in between a "tight fit" and a "similar fit". This means that the outer races will not rotate in the housing, but with moderate hand force they can be moved back and forth. I don't think that wiping a bit of extreme pressure grease inside the gear housing will change that, and it should help prevent corrosion and fretting damage.
