how to cut 4 groves per inch
Jay Moore
Dec 14, 2010
Albany, GA
Hi Everyone,
This site has been very helpful, thanks.
Another project, I would like to cut 3 to 5 grooves per inch on a face
Like a clutch disc 11.000" OD and .650" wide face
in other words, oil grooves from inside/ outside
grove width 0.020" x 0.030" deep
like a spiral that is 75% of a single turn
any ideas please respond,
tks again
j
send to a shop. bam!
-they will stick it on a cnc mill or live tool lathe.
nobody has time or inclination for gearing a rotary table to a mill handle anymore. .020" wide? by .030" deep? well... that sucks much rather do that on a lathe.
a decent live tool lathe could probably spin the part slowly with a simple grooving tool.
a decent mill with 4th axis could hold a grooving lathe type cutter in the head, and spin the part below it while traversing. sort of like a lathe. and much faster than using .020" endmills.
the fastest feed rate or TPI is (11) on a deblond
That's unusual, most 8-12" lathes will start with 4-6 TPI I think. You can always compound the pick off gears but beyond a certain ratio you want the feed shaft to drive the headstock instead of the other way around, the normal way.
He needs face grooving, not axial threading. So it's the cross-slide feeds that matter. And unless he can put together a tandem set of speed reducing subheads (he can't), there's no chance that a powered cross slide feed on any sane lathe will be that fast.
Jay Moore, you've already been recommended to send it out to a shop with CNC gear. If you don't want to do that, there are some old-school (like 19th Century) methods that might serve, but you're going to have to improvise a bit. There is no hidden panel behind your lathe's threading chart that will activate the functionality you need.
What I'm going to describe can be done on either a lathe or a mill with a rotary table. I'm going to be lazy and give a generic description, instead of explaining every detail about how the lathe and mill setups would differ. This may be confusing.
First rig an appropriate milling spindle. On a mill, use the mill. On a lathe, mount something on the compound like a toolpost grinder, only with a milling cutter.
Now you need to synchronize a 75% rotation with a fairly short linear travel, whatever the effective annular width of your clutch plates is. You need to consider the mechanical advantage here. You want to drive with the least leverage, meaning the applied force/torque is less than driving from the other end, keeping in mind that you're not just going to move the parts but also force the workpiece into the cutter. (That's what partsproduction was getting at in the preceding post.) I'm going to guess that rotation should drive linear travel in this situation. That means disconnecting your cross-slide (lathe) or saddle or table (mill) feed screw, and using another mechanism to push/pull the slide. Depending on the size of your machines, this may be easier to do on the lathe.
There are a couple of ways to couple the rotation to the linear travel. Rack and pinion is one. A metal band winding up on a spool is another, as you can totally ignore the non-linearity due to accumulated band thickness on the spool. The ratio between rotation and linear travel is controlled (completely) by the pinion/spool diameter. If the ID of the annulus you need to groove is less than the necessary spool diameter, you can stack the pinion/spool right on top of your workpiece. If the annulus ID is smaller than the necessary spool diameter, you have to work around that so the spool doesn't interfere with the cutter. Put the pinion/spool on top of your rotab, then stack an auxiliary table on top of the pinion/spool to mount the workpiece on.
Oh yeah, the loose end of the band/rack needs to be mounted to the fixed frame of your machine if you're using a mill. If you're using a lathe, the loose end would be mounted to the cross-slide. And if you're using a rack, you need a guide to keep it from pushing away from the pinion.
For each cut, unwind the rack/band, take up the backlash, and index your part to the next groove. Engage the milling spindle and plunge. Rotate the work, which will wind up the rack/band and pull the saddle/table/cross-slide forward.
I think I would do this on a mill with a rotab, rather than a lathe, because the rotab would give a lot better control of the cut than trying to rotate the lathe spindle by hand.
OK, that was technique A. Here's technique B. Make a cam that follows your desired groove curve. Mount the cam on the faceplate/rotab. Mount a cam follower on the cross-slide/fixed frame. As you rotate the faceplate/rotab, the cross-slide/saddle will move to follow.
Here's technique C, which is a variant on technique B. Make a cam that follows your desired groove curve, double-sided aka slot cam would be wanted here. Mount the cam on your welding table. Build a 2D pantograph with a cam follower and a "slow-speed router head" suitable for milling, with just enough 3rd axis motion to disengage the "router" from the work.
If all that sounds like a pain in the ass, Jay Moore, send your parts out to a shop that has more appropriate equipment.
Maybe abandon the spiral and mount the disc off center with a 4 jaw and groove it. Make it so the circle of the groove is almost tangent with the OD of your part on one side and tangent with the ID on the other side
as suggest by partsproduction above.
you need a lathe with power cross feed linked to the spindle that can be configured for the equivalent of 4tpi (his leblond apparently only capable of 11) i.e a machine with change gears that'll spin the drive shaft much faster than normal .
With a suitable cutter (i.e toolpost grinder adapted to milling) you can then drive the spindle by hand (or better, the fastest moving accessible part like the gearbox drive shaft.) back and forth to make your groove (s).
In my home shop , I'd choose the cnc mill (if it would take 11" disc?) or perhaps my little horizontal with some jury rigged gearing on the power feed. I might be able to get the hardinge to do a 4 tpi spiral once but it's crosssilde power feed is not sync'd to spindle so multiple passes would not be possible.
