I have an ACRA Model 18VH vertical mill variable speed head disassembled to repair the drive components. I had expected to find some plastic bushings in the drive pulleys as is common in BP's and several other brands. However, as best I can tell there are no bushings. The movable pulleys are machined to run directly on the shaft. The sliding spindle drive pulley seems to be in good shape. The motor sliding drive pulley has about 0.017" clearance over the motor drive sleeve. Also the movable motor drive pulley has a bearing surface only at the top near the belt track. has anyone run into this before? Any creative repairs?
Keith
Keith
