jscpm
Titanium
- May 4, 2010
- Cambridge, MA
We need to cut some masonite to be used as templates. The shapes are only large circles, radii and straight lines. In some cases the templates are pretty big, several feet in diameter or larger, so in a lot of cases it is hard or impossible to mount them on machine tool beds.
We tried a scroll saw first. That has the problem that the table does not easily accommodate guide fixtures and it takes a lot of skill to freehand a circle or line using a scroll saw. Also, the line produced is never perfect, but has little tiny jogs in it. Also, the typical scroll saw has a 20" size limit.
The next idea was to use fly cutters. The problem is that the masonite is soft, so the cutter tends to dig it up and form wharfs on the work. I think if the geometry of the fly cutter was correct, I might be able to get a clean circle, but before doing a lot of experimentation with different geometries, I wanted to ask here to see if anybody knows the right shape.
Another idea I had was to use some kind of Dremel setup. Like make a circle cutter and mount the Dremel in it and use a small end mill.
Obviously, I could be sending it out to a waterjet shop or something like that, but it would make my life simpler if I could do these templates in house.
