How to debur sheet metal? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21
    Mar 2005
    Northwest Indiana
    4,216
    845
    846
    I also use a sharp file for deburring sheet metal. Quick and works great.
  2. #22
    Oct 2014
    Arkansas
    181
    36
    If the parts aren't flat and you are making a lot of them, vibratory finishing can deburr a lot of parts. 1000's. In a short amount of time. And they will all come out nice.
  3. #23
    Mar 2006
    Wisconsin
    1,085
    14
    368
    I use 3M Scotchbrite wheels on a long arm pedestal buffer.
    Here's a link to the deburring type of wheels I use:
    Buy Convolute Wheels - Free Shipping over $5� | Zoro.com
    This is a buffer similar to the one I use. Mine has a long arm on each side.
    Queen City longarm buffer grinder 16in long arm pump drum sander | eBay
    It makes quick work of both large and small pieces.
  4. #24
    Sep 2004
    RSA
    1,101
    394
    279
    A NOGA ( 1003 ) will beat a file by many miles. Won't clog and it'll last forever. One of the few tools which works wonderfully.
  5. #25
    Jun 2015
    CANADA
    British Columbia
    1,191
    263
    620
    I am using a fine Rubberized Abrasive Wheel on my 10" bench grinder. It is easy to create a V groove in the wheel. Running the periphery of the sheet metal in the V groove leaves a nice, smooth, slightly rounded edge. Controlling the pressure on the part can just remove the burr or round a little both sides.
    Quite small parts can be deburred by tumbling or thermal energy method (TEM). I've used both process successfully on 5-10mm long complex parts in stainless.
  6. #26
    Jul 2014
    New York
    18
    We generally use belt grinders. The faster FPM units (approx 4,000 FPM and above) are much more effective than slower units. Also, the belts last much longer on the faster units.
    It is also nice to have grinders where you have the choice of grinding against something hard (such as a backup plate, or a contact wheel) for more aggressive grinding, and also against the unsupported belt which is more forgiving and better for delicate items (or aluminum which is soft and grinds very quickly).
    We have tried a dedicated sheet metal deburring machine - the Falls Products Deburr machine, however we were never able to get it to work properly and its manual was really amateurish.
    We're still looking for something faster. Has anybody tried this thing: Heck Turbo Burr ? It looks like it is a die grinder with a burr bit, coupled with a V block to guide the part to the right location. Anybody ever try this?
  7. #27
    Sep 2012
    Staffordshire, UK
    9
    21
    Default How to debur sheet metal?
    Deleted post
  8. #28
    Langley, B.C.
    1,701
    351
    994
    Quote Originally Posted by AlexO View Post
    I agree. We've used one for years and for real sheet metal (16 GA or thinner) it will outperform any other method
    we've tried. Not only because it's faster but because you get consistently deburred edges over an entire part. The
    only place they don't work too well is in tight corners or holes but if you're working with sheet metal your deburring
    should be done long before you get to the forming stage...
  9. #29
    Nov 2003
    5,040
    176
    1553
    And just HOW do you cut sheet metal without leaving a sharp edge or burr on at least one side?
    A torch, perhaps?
    Quote Originally Posted by WILLEO6709 View Post
    Fastest way is to not make a burr in the frst place...
