atomarc
- Mar 16, 2009
- Eureka, CA
I have a steel framework that holds 240 extruded HDPE 'sticks' that are 4" wide by 2" high by 13 feet long. They are in contact with two steel frame members across the 13 foot dimension. When a single 'stick' is pushed with a force gauge, it measures 2.5 pounds of force to move the 'stick'. If you consider all 240 'sticks', this would mean that to move all of them together it would take approximately 720 pounds of force.
The question! What math do I apply to properly size a gear-motor to move this load(all 240)? The load will move a distance of 24" in 15 seconds, wait and repeat.
I have always sized prime movers in a situation like this in cowboy fashion, but in this instance I need to be a little more in the ballpark, versus the rodeo grounds.
The explanation must be simple...I'm just an old Millwright.
Stuart
Stuart
