How do I improve contrast on a taper scale?
Results 1 to 11 of 11
    Jul 2016
    34
    9
    Default How do I improve contrast on a taper scale?
    This is the taper scale from my KO Lee tool and cutter grinder.
    As you can see it is hard to read. What would you do to improve its visibility?
    Gary
    Nov 2013
    Eastern Massachusetts, USA
    3,913
    4282
    4128
    Perhaps rub over it with a lacquer stick and then wipe off excess on a single sheet of newsprint damp rather than wet with lacquer thinner. The newsprint needs to be stretched on a flat surface so it only wipes the top surface, not the recessed markings. you turn the scale face down onto the newsprint while wiping.
  3. Likes sfriedberg liked this post
    Dec 2014
    Arizona
    359
    38
    56
    Yep, got to it first, I think it would work pretty good. Or you could use the little paint bottle that has a needle on the end.
    Jun 2012
    Michigan
    4,509
    4108
    2669
    Black oxide it, then paint the markings white?
    Virginia
    25,746
    7561
    8122
    These days?
    Look for an electronic replacement I could adapt.
    Stuff has gone cheaper than time wasted or errors made, long since, can improve USEFUL accuracy and improve throughput of even some rather tired platforms it gets hung onto.
    Aug 2008
    Sussex, England
    3,340
    12
    712
    Last one of that ilk I just laser printed and laminated. If it wears out I'll call up the file and do another one. Life is too short for the level of detailed futzing around needed to do a good refurb job.
    Which I have done back in the day when there was no alternative. But takes ages to get it right-right. Staring at a crap or "well sort of OK" job puts my temper in the danger UXB red zone too fast for comfort!
    One before that couldn't accept a lamination job so I made it from scratch. Rotary table and engraving cutter on the Bridgeport. Do not disturb notice on the door. Got 'er done surprisingly fast. Getting my eye in on the number stamps was possibly slowest part.
    Clive
  8. Likes Pathogen liked this post
  9. #7
    Dec 2008
    New York
    10,029
    2605
    Quote Originally Posted by garyrice View Post
    Gary
    walmart sells kids paint. florescent green mixed 1/2 and 1/2 with glow in the dark paint works wonders. even after using flashlight it glows by itself for quite some time. they sell black paint too
  10. #8
    Jul 2008
    Waltham, MA
    418
    94
    Sandblast it, then nickel or chrome plate. Blacken the engraved lines with lacquer or carbon black or marker
  11. #9
    Aug 2004
    Winchendon, MA USA
    802
    231
    Use gun bluing then with a scriber scratch all the lines tada done.
  12. #10
    Sep 2017
    Arizona
    39
    8
    Use a white grease pencil to fill in the engraved marks.
  13. #11
    Feb 2010
    ch
    2,093
    194
    274
    tip-ex also works.
