How do I indicate a threaded hole?
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 83
    Jul 2004
    Carlisle, MA, USA
    110
    Default How do I indicate a threaded hole?
    I have some holes that I would like to machine, and they are currently threaded. How do I indicate them to precisely find center on my mill?
    Ray
    May 2007
    Massachusetts
    968
    14
    148
    Look up "locating screws". Alternatively, a shoulder screw could get you close if you indicate the ground diameter.
  3. Likes mhajicek, PegroProX440 liked this post
    Jan 2010
    Arizona
    64
    24
    It depends upon whether you want to locate the centerline of the pitch diameter or the centerline of the minor diameter. The pitch diameter is more accurate but it requires a plug gage like these. Threaded Hole Centerline Location Gages. If you just want to locate the minor diameter (depending upon how accurate you need to be, this might be good enough) you just need to find the largest plug gage that will slip into the threaded hole, and then indicate that.
  5. Likes boslab liked this post
  6. #4
    Jan 2007
    wales.uk
    1,915
    437
    455
    Screw a go/no go guage in without the handle, clock the stem, works
    Mark
  7. Likes mhajicek, Dupa3872, SteelrFn liked this post
  8. #5
    Jul 2004
    Carlisle, MA, USA
    110
    I do have some tight fitting studs that I can machine and then screw in and indicate off, but I don't know just how close that would be. I am also looking for pretty close (I don't actually have a tolerance) as this is a bolt hole that will get studs installed.
    Beege: what part of MA are you in - I am very close to Chelmsford...
    Ray
  9. #6
    May 2007
    Massachusetts
    968
    14
    148
    SouthEast MA, near Brockton.
  10. #7
    Dec 2008
    Vt USA
    9,679
    1745
    3573
    Run a nut up the threads of a good quality cap screw. Cut the hex head off the screw
    Thread the screw into the hole as far as it will go, but don't bottom it out. Snug the nut down to the surface.
    Indicate off the unthreaded shank of the cap screw.
    Or just use a shoulder screw as mentioned.
  11. Likes Greg White, Antarctica liked this post
  12. #8
    Jan 2007
    Flushing/Flint, Michigan
    11,098
    664
    8877
    Quote Originally Posted by just4grins View Post
    Some just use tight fit gauge pin but this better and costs more so often gauge pin for me.
    There is a difference as one is the drilled hole and the other the threads.
  13. Likes Garwood liked this post
  14. #9
    Jun 2012
    Michigan
    14,375
    4898
    5202
    You might turn a piece between centers having a going-tight-thread,
    That is thread that goes into an Ok nut but having an increase in size that makes it lock up in the nut.
    Making it leave a straight shank of a size that will be easy to relate to, for the gauging from straight diameter.
    offsetting your tail .003 .005 per inch might be a good taper,
    But this is checking after the fact..not placing them in the right place.
    Putting in a high-quality stud, and adding a locking nut would be good Only if you were assured the locking nut had dead true face to thread geometry.
  15. #10
    May 2011
    New Jersey
    3,574
    410
    2024
    Indicating threads is a crap shoot really. If they are not dead square you will get a false reading. Any wear can get you a false reading. When I pick up threads on a Bridgeport I find a snug gage pin and put it in the spindle and poke till it goes in...nothing fancy there lol.
  16. #11
    Jun 2008
    Dassel,MN,USA
    240
    41
    100
    did not see this mentioned above.
    run a tap in, indicate off the round top of the tap. should be a bit better than using a looser fitting bolt.
  17. Likes michiganbuck, mike44, Nagol, Bobw, Winterfalke and 1 others liked this post
  18. #12
    May 2011
    New Jersey
    3,574
    410
    2024
    There's a reason most machinists (I say most because there's always retards) don't indicate off threads for something that has to be precise is because the tapped hole isn't precise...and if you attempt to do this, well my friend, you are retarded.
  19. Likes PmGRacer, Mtndew liked this post
  20. #13
    Feb 2006
    Indiana
    14,098
    827
    4824
    A different approach would be to start by precisely measuring the hole locations in the mating part and make a drawing. Apparently, the end result is to have larger tapped holes that line up with drilled holes in the mating part. Keep the desired end result in mind when planning the job.
    If the plan is to replace the threaded holes with larger threaded holes, I am guessing that new studs will be made with the larger thread on the end that goes in the tapped holes and will have the remainder with the original stud size to fit through the holes in the mating part. Or maybe the plan is to use an STI tap and use the original studs.
    Either way, you need to enlarge one threaded hole and then locate the other holes from the first using your measurements of the mating part.
    Larry
  21. Likes plastikdreams, Iceking007 liked this post
  22. #14
    Jul 2004
    Carlisle, MA, USA
    110
    Thanks guys,
    I do appreciate the help even if some consider trying to better oneself as the mark of a 'retard'!
    Anyway, I know the bolt hole circle, so I could indicate off the center and then move out the radius, but I am trying to install dowels in the existing holes that are a bit larger than the existing studs.
    I will try a few things as I have some spare units that can be written off.
    Ray
  23. #15
    Mar 2009
    6,607
    131
    1275
    What thread size are the existing holes and what is the fit gauge number like from the tap that might have made the holes?
  24. #16
    Jul 2004
    Carlisle, MA, USA
    110
    thread is 14mm x 1.5, fit is not that great. I put in what I thought was a tight fitting stud, and drove it down and was able to move it in the hole by hand +- .005.
    This may just be a problem to throw money at...
  25. #17
    Virginia
    22,137
    7561
    12728
    Quote Originally Posted by rbahr View Post
    So long as it is rons' money? We could be OK wit' dat'?
    Kinda like a pre-paid vacation funded by the randomly curious.
    Or was it random curiosity?
  26. #18
    Apr 2018
    9,792
    4705
    Quote Originally Posted by beege View Post
    Best answer. Shoulder bolts / stripper bolts are made on purpose to be square and true to the thread, and they are pretty cheap and readily available.
  27. #19
    Jul 2004
    Carlisle, MA, USA
    110
    Ok, I will look for some shoulder bolts.
    Thanks for all the suggestions!
    Ray
  28. #20
    Apr 2018
    9,792
    4705
    Metric, eek, sorry. You just said that part I've only used inch. Hope they are available in metric, too.
