How does a soldering station work
Likes Likes:  0
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Apr 2004
    Modesto, CA USA
    7,340
    1275
    Post
    I picked up a soldering station at a thrift store. a older weller with no temp control knob. I found no info on the internals so I would like to know how it works seems like a transformner inside the box. The tip is maybe spring loaded. so how does it sense temp and control the power to the iron.
    bill D.
    Apr 2004
    Modesto, CA USA
    7,340
    1275
    Post
    bill D.
    Apr 2004
    Modesto, CA USA
    7,340
    1275
    Post
    bill D.
    Apr 2007
    N. Ireland
    260
    Post
    Without knowing the exact model, i assume the transformer is for mains isolation.
    For an insight re temperature controlled iron http://www.uoguelph.ca/~antoon/circ/wlc100.html
    Mark
    Apr 2007
    N. Ireland
    260
    Post
    Mark
    Apr 2007
    N. Ireland
    260
    Post
    Mark
    Jun 2006
    Beaverton, OR
    5,458
    57
    Post
    Usually they are 24v ac powered. In the tip on some of the wellers there is a temp device that sets the thermostat. I believe its all in the handle on those.
    Jun 2006
    Beaverton, OR
    5,458
    57
    Post
    Jun 2006
    Beaverton, OR
    5,458
    57
    Post
    Oct 2003
    Idaho
    2,878
    588
    377
    Post
    The tips are available in different heat ranges.
    They connect/disconnect in the barrel.
  11. #11
    Oct 2003
    Idaho
    2,878
    588
    377
    Post
  12. #12
    Oct 2003
    Idaho
    2,878
    588
    377
    Post
  13. #13
    Aug 2003
    SD, CA
    163
    Post
    These rely on changes in the magnetic charactistics of the tips at the temperature set point.
  14. #14
    Aug 2003
    SD, CA
    163
    Post
  15. #15
    Aug 2003
    SD, CA
    163
    Post
  16. #16
    Apr 2007
    Central MA
    984
    23
    Post
    The temperature is controlled by the tip. There's a magnet inside the tip the loses its magnetism at a set temperature. This shuts the heater off. Tips are available for 600, 700, and 800F. Search www.newark.com for "WTCTP".
    These are current model "production" soldering irons and are a very nice iron - for electronic soldering.
    The heater runs on 24V from the transformer.
    Edit: fat-finger-itis, it's WTCPT
    Aaron
  17. #17
    Feb 2004
    peekskill, NY
    25,073
    4994
    Post
    If it has the knurled ring at the base of
    the iron shaft, near the handle, do this:
    1) turn off the iron and wait for it to cool.
    [img]smile.gif[/img]
    2) unscrew the knurled ring and remove the
    ring and sleeve.
    3) remove the tip and look to see if it has a
    number at the base.
    If so the number will be 6, 7, or 8 which
    indicates 600, 700, or 800F operating temp.
    There's a microswitch in the handpiece which
    opeates via a magnet in the tip. The magnet
    cycles in and out of its curie temperature to
    control the power flow to the tip. Cute idea
    actually.
    "Weller Magnastat" is the trade name.
    Jim
  18. #18
    Apr 2007
    Central MA
    984
    23
    Post
    Aaron
  19. #19
    Feb 2004
    peekskill, NY
    25,073
    4994
    Post
    ring and sleeve.
    number at the base.
    actually.
    Jim
  20. #20
    Apr 2007
    Central MA
    984
    23
    Post
    Aaron
