How to enlarg holes in hardened 123 block?
stoneaxe
Stainless
Mar 2, 2010
pacific northwest
I have a couple of cheap Chinese 123 blocks with holes- half of them tapped to 3/8" and the other half through holes. One would imagine in some logical universe the through holes would accept a 3/8" bolt, but no- they are slightly smaller.
I want to use some existing tee nuts in the table and drop a bolt through, so I tried to drill one out- no go.
Is there some easy way to drill these out, or should I toss the POS and buy some that will work? I do not want to spend the time to set up on the mill, center every hole, and use an end mill. Will a straight flute carbide drill bit self center in the holes with no clamping?
I know this is stupid- I mean, one broken bit and it is the cost of some new blocks... But still, curious if it would work- I have drilled thousands of holes on the drill press without clamping to the table, just letting the entire vise and part float so the drill would self center- just have no idea if a carbide straight flute would do this.
I imagine this is an errand in futility, but could you mount them to a lathe faceplate and either grind or bore them?
Hard to know how hard these are given the likely absence of much QA, but most 1-2-3 blocks are hard enough -- and with deep enough holes - that you'd likely go through $200 of carbide die drills to maybe get the holes on these $20 blocks larger. Just as likely chip the outer edges of the drills and give up. It's pretty tough duty to use just the outer lips of any bit on anything super and erratically hard.
It's really a job for grinding, once they've been hardened. Could test with a file, though, to see how hard they are, how deep the case, etc.
Assuming the threaded portion will pass (and if not, they really are a piece of crap), you might be able to quickly neck down some bolts or cap screws to fit.
It is probably not worth the time if you are in a professional environment. Just get some 1-2-3s that are properly made. Even if you enlarge the holes in the imported blocks, you will find that the spacing of those holes is now very good and bolting them together will be problematic.
I think Suburban Tool has one such set. They will cost more than the imports but the holes will accept bolts and will line up nicely when you assemble the blocks.
PRECISION 1-2-3, SETUP & TRI-BLOCKS by Suburban Tool, Inc.
If you are going to enlarge those holes I think a carbide bit will be at great risk of fracture. I would suggest using the same technique that can be used for drilling a hole in glass. Get a brass tube of the desired diameter. File some notches in the end: leave about 50% of the original end and 50% in the notches. Mix up some abrasive and oil. Mount the brass tube in the drill press and dip the end in the abrasive mixture. Use that as an abrasive drill bit. Start with light pressure and increase as the cutting action begins. Refresh the abrasive-oil mixture as needed. Slow going, but a lot easier to control than any drill bit and the brass tube will not fracture like carbide will.
All the usual disclaimers: I have no relationship with Suburban Tool.
I have a similar pair, the bolts they included in the box don't even screw in... As blocks they're fine, but not woth modifying so I use them "beater" work with small thru bolts if fastening is needed. Good 123 blocks are not all that expensive- I have a set of Fims blocks that I really like and some a couple pairs of yardsale blocks.
A set of 2x4x6 blocks are occasionally handy, I went ebay on those to gamble on lightly used good quality blocks rather than the cheap imports. I don't need the big ones enough to justify new high quality units.
I'd probably use up some old beater endmills on a job like this. This is one reason I don't sell my old carbide, there is likely some salvage in scrapped cutters that makes the scrap of more value in my hands than a couple of dollars from a scrap man.
However, you do have to securely clamp and find each hole to use an endmill without immediately destroying it, and you'd have to wind up with the knee to control the feed.
But little grinding points for a die grinder are cheap and might do the job on a few holes. A carbide burr will probably also serve, but will likely not last very long as well.
many times you really dont need precision ground 1x2x3 blocks for much of anything. cold rolled steel even if .001 undersize is usually the same thickness if you cut from close to same part of bar. sure bar might be gentle wavy .0005" over 12 foot lengths
and if you bolt steel to table and machine or trim them they are then the same height cause you machined them same time. and of course .001" and .0012" (.03mm) and .0015" feeler gage stock comes in rolls you cut to length needed and is used to shim parts using a indicator
just use a old 3/8" carbide endmill ... free hand grind a 45* angle on the corner and use it to drill out the holes ... most 3/8" bolts are under size so a 3/8" hole would work good .
