How hot to heat a bearing for press fit? - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 44 of 44
  1. #41
    Jan 2005
    The Netherlands
    6,688
    365
    1941
    At least those needle clutches can handle more RPM
    5500 it was i think
    Peter
  2. Likes Terry Keeley liked this post
  3. #42
    Sep 2010
    England Wakefield
    13
    6
    Default The bearing supplier will have a bearing heater
    Quote Originally Posted by Terry Keeley View Post
    I have a 6203 (17mm bore) ball bearing to heat up for a n6 press fit on a shaft (12-23 microns / 5-9 tenths).
    I see the plates go to 400F or so but am not finding any info on "the Google".
    The bearing has some sort of plastic cage...
    The supplier of bearings should have the correct tool for this, properly made heaters are available if you have use for one.
  4. #43
    Feb 2010
    ch
    3,260
    272
    449
    it has to be kept in mind that the tempering/annealing prozess is temp. and time dependent. there might be no effect of heating to 200° for a few seconds, but dont leave it there for 30 min. (→induction heater).
  5. #44
    Jan 2010
    Atlanta, GA
    155
    48
    I"ve had good luck by heating the bearing with a heat gun and shrinking the shaft with the cold generated from spraying the dustless computer spray can upside down. the spray immediately drops the temp to below freezing and the technique seems to work ok if the bearing is heated a little.
