woodfarmer
- Nov 11, 2014
My lathe is an old Holbrook with max speed of 400 rpm. min 15 rpm the finest cut is 112 per inch about 9 thou or 1/4 a mm
I need to make some cylinders about 1 1/2 inches internal diameter from EN19T which is a hard steel. I have done a fair amount of machining stainless steel with HSS tools at a very low speed 50-80 rpm.
The cylinders need to have a closed flat end but a small 5-10 mm hole in the centre would not be a problem. Initially I though to buy an indexing boring bar but now not sure they would work in my lathe.
Does anyone have a suggestion. It is a job for myself so time is not a consideration even if it took a week to make each one. Cost of tips or other tooling could be.
I need help .......
I need help .......
