MrCreosote
- Aug 27, 2011
- Pennsylvania
This is the common symmetric ferrule:
http://www.horrorseek.com/home/halloween/wolfstone/Plumbing/concom_OnTube.png
I have a 9" South Bend lathe with 3-jaw chuck.
I'm thinking,
*) turn OD and drill ID on some chucked bar stock.
*) turn cone on end
*) turn as much cone as possible on inboard end without parting it off
*) have to make a parting tool with the cone angle to complete the inboard cone and part off.
The problem with this is that the parting took completes the inboard conical surface which is not what you when parting.
Don't know how good this would work machine all outside features and drill hole as last operation. The cones would be turned to smaller than the drill ID. Of course the last bit of drilling would perform the parting and again would be problematic with a gouge and rip off of the ferrule. BUT, the chuck jaws would be long enough to clamp the bar and the ferrule OD at the same time and perhaps this ferrule clamping would be enough to keep it in place as the drill intersected the inboard OD cone, cutting it off.
______________
I don't think it would be possible to chuck the ferrule itself on its OD and machine the cone feature. If I had a collet I would think it possible, maybe even with a 6-jaw chuck.
______________
Support ferrule on some kind of mandrel, possibly tapered.
______________
Obviously screw machines pound ferrules out in seconds so I wonder how they are set up?
_______________
ANOTHER QUESTION: How to increase the ID bore diameter of an existing stainless steel ferrule?
Chuck on OD?
Make a "Compression Chuck" that would hold the ferrule as it is in its compression fitting. Perhaps install in compression fitting, align with tubing, remove tubing, tighten, and then drill out the entire compression fitting.
In fact, this might be a way to make the ferrule too: machine outside features and then drill a much smaller ID - small enough that the ferrule is still on the bar. Then part off.
Align in compression fitting and begin progressively drilling out ID.
__________________
I'm done. I'm really curious what the operations are on a screw machine that manufactures them.
THanks in advance,
Tom
I'm thinking,
*) turn cone on end
______________
______________
______________
_______________
Chuck on OD?
__________________
THanks in advance,
Tom
