roboticmehdi
- Jun 30, 2020
Hello,
Automatic generation of gages method is used to make accurate and precise flat surfaces.
I am very interested in knowing how can one make an accurate cylinder using similar techniques or other techniques.
How accurate? Well, as accurate as it can get for a machine part or something, just very accurate, maybe like as accurate as cylindrically shaped parts inside a modern car engine.
(SI) Basically, to make a very accurate cylinder, for example 200mm long and 50mm diameter, without using any accurate modern tools.
I when I measure the diameters in multiple places along the cylinder, result be 50mm +-0.01mm at worst.
(US) Basically, to make a very accurate cylinder, for example 8000mil long and 2000mil diameter, without using any accurate modern tools.
I when I measure the diameters in multiple places along the cylinder, result be 2000mil +-0.4mil at worst. (mil=thousandth of an inch)
Basically an ancient man, who knows how to cast metals into crude/inaccurate shapes (as accurate as can be handmade), (and maybe also knows how to make a surface plate if thats definetely a requirement for a cylinder?), trying to make an accurate cylinder.
Hope I could explain my thought and hope to get your very good helps.
For years this question puzzled me. No one likes prisons.
Thanks in advance.
Thanks in advance.
