how to make an accurate cylinder
Likes Likes:  0
Results 1 to 10 of 10
    Jun 2020
    AZERBAIJAN
    Default how to make an accurate cylinder
    Hello,
    Automatic generation of gages method is used to make accurate and precise flat surfaces.
    I am very interested in knowing how can one make an accurate cylinder using similar techniques or other techniques.
    How accurate? Well, as accurate as it can get for a machine part or something, just very accurate, maybe like as accurate as cylindrically shaped parts inside a modern car engine.
    (SI) Basically, to make a very accurate cylinder, for example 200mm long and 50mm diameter, without using any accurate modern tools.
    I when I measure the diameters in multiple places along the cylinder, result be 50mm +-0.01mm at worst.
    (US) Basically, to make a very accurate cylinder, for example 8000mil long and 2000mil diameter, without using any accurate modern tools.
    I when I measure the diameters in multiple places along the cylinder, result be 2000mil +-0.4mil at worst. (mil=thousandth of an inch)
    Basically an ancient man, who knows how to cast metals into crude/inaccurate shapes (as accurate as can be handmade), (and maybe also knows how to make a surface plate if thats definetely a requirement for a cylinder?), trying to make an accurate cylinder.
    Hope I could explain my thought and hope to get your very good helps.
    For years this question puzzled me. No one likes prisons.
    Thanks in advance.
    May 2019
    Michigan
    1,401
    387
    627
    Quote Originally Posted by roboticmehdi View Post
    Thanks in advance.
    Please explain......
    Oct 2009
    Louisville, KY, USA
    996
    214
    219
    Generate a flat surface as a bed for your lathe. Turn a cylinder.
    If you insist on not using a lathe. Generate a straight edge and a make a diameter gauge, keep scraping your rough cylinder until it is straight and to size.
    I imagine you're looking for something analogous to the three plate method of generating flat surfaces. You could generate a square with the surfaces too, but an accurate cylinder requires that you hold a specific dimension, which is a different puzzle.
    Oct 2005
    17,694
    Quote Originally Posted by fciron View Post
    The OP is not "looking" for anything...only google rankings, which they have achieved by posting here.
    Jun 2012
    Michigan
    11,621
    3968
    4132
    Perhaps two stones cut with a harder stone and rubbed together to make a taper that would expand the diameter as the stones were brought together and the taper moving the stones outwardly...perhaps also using a grit of sand or other particles.
    Sep 2006
    Stillwater, Oklahoma
    1,481
    110
    813
    No opinion on whether the OP is posing a legitimate question, but presuming he/she/it is.
    For generation of reference tools it makes a lot more sense to develop a right angle square rather than a cylinder. This you can do by generation to the limit of your measuring instruments.
    If he/she/they really want an accurate cylinder, lapping would be the way to go, again limited only by patience and measurement ability.
    Dec 2012
    AUSTRALIA
    2,879
    12
    936
    Think the OP is asking a history/ archaelogical question ,needs a pass in history to offset the F- he s getting in English ....Actually James Watt faced the same problem in building large atmospheric engines .....the 10ft diameter x 20 ft stroke cylinders were hand finished by scraping and chiseling "accurate to the thickness of a shilling" out of round and straight by using a taut string as a measure.
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,118
    936
    738
    A lathe is not a modern machine tool, but very ancient. A crude conical point poked into a crudely-matching conical hole in one end of your only-roughly-cylindrical workpiece will hold its position. If you do that at both ends, it will revolve around an axis. If you maintain contact as your rough centers wear-in, you may achieve stable, accurate rotation around that axis.
    Then generate two intersecting accurate flat surfaces: a prismatic way. Set it up approximately parallel to your workpiece's axis of rotation, and use it to guide a cutting tool. The deviations form true cylinder will guide you to get the alignment closer and closer, until your workpiece becomes "cylindrical" to the limit of your ability to measure.
    That is the theory looked at through wrong end of a telescope. Hundreds of years of practice is available for study.
    Jan 2005
    The Netherlands
    6,030
    292
    1621
    Quote Originally Posted by magneticanomaly View Post
    A crude conical point will not genarate a straigt line
    It will wobble
    I would sugjest to do it like its done
    Start with a rough machine and with that make a better one with a lott of skill
    With that make yet another better one And so on
    No shortcuts found so far as I know of
    Peter
    Jun 2012
    Michigan
    11,621
    3968
    4132
