How to Manufacture Gutter Guard
Results 1 to 16 of 16
    Jan 2011
    Kansas
    744
    52
    59
    Default How to Manufacture Gutter Guard
    I have attached some photos of an aluminum mesh gutter guard that a local guttering company uses. It appears to be powdercoated, but they don't require that. They have a really hard time getting this from their supplier and can never get more than a half pallet of it at a time. They are asking me what it would take to form/manufacture it. It would be some kind of roll machine I imagine. You can flex and manipulate it by hand. The current form is what they purchase it in, but they would like to modify the form some. Any ideas?
    Attached Thumbnails Attached Thumbnails profile.jpg   gutter-guard-top.jpg   closeup.jpg
    Jan 2005
    Victoria, Texas, USA
    4,256
    2575
    1117
    Before you try to come up with something, better check and make sure there isn't a active patent on that stuff. Just saying. Ken
  3. Likes JST, bryan_machine, Dualkit, TDegenhart liked this post
    Jul 2006
    Hillsboro, New Hampshire
    9,342
    2207
    6471
    That seems to be just expanded mesh cuts, done using partial piercing/splitting cutters that perforate the sheet, then a controlled stretching is performed to open up the mesh as desired. Perhaps a secondary embossing was done in order to "round over" the segments after piercing, this could be done in a rolling operation.
    I doubt there's anything patented here, expanded mesh has been available for a dog's age (many dogs), and should be commercially available from metal sheet producers (unless all that's gone overseas now).
  5. Likes rcoope liked this post
  6. #4
    Oct 2010
    Oregon
    5,311
    4802
    1952
    If I wanted to make 20 or 40 feet of the stuff, I'd buy 4x8' (4x10' if I could get them) sheets of premade expanded metal or perforated metal, shear off the necessary widths, and make the solid (unperforated) edges by folding over and crimping on sheared strips. Maybe adapt a lockformer machine for that.
    If I wanted to make 1000's of feet of the stuff, I'd try to source the machine that makes it. Designing and debugging a homemade machine to produce it would be possible but a large investment in time. Light gauge aluminum is not too hard to pierce, so this would be a bit less troubling than trying to make expanded metal mesh from 1/8" stainless, but there's still a bunch of slits to make and register from row to row, etc.
  7. Likes avto762 liked this post
  8. #5
    Dec 2003
    Washington
    4,873
    2404
    4424
    These guys should be able to help you or at least give you an idea of where to get more than you could ever use . . . AMICO Product Line
  9. #6
    Aug 2012
    California, Central Coast
    4,444
    2288
    1777
    I have some of that stuff for my gutters. What I have is just the expanded metal bent in a similar profile, no solid edges on it, 100% expanded metal. I think on the ones I have the expanded is going lengthwise, 90º to what you have there.
  10. #7
    Virginia
    31,460
    7561
    9880
    Quote Originally Posted by Rob F. View Post
    Tried an earlier conventional "diamond mesh" version. It sucked. Grabbed leaves and held them 'til they rotted.
    Plastic with round holes worked better. The leaves slid off or blew off once dry.
    Still not great. Pine needles and airborne "winged" seeds went through.
    NOW using a full cover with a reverse "S" curve to a slit that water follows, but leaves and such do not follow.
    Works a treat! Looks better, too!
    So I'm sayin' regardless of how to make this expanded metal version?
    The product itself may no longer be as viable as it once was.
  11. Likes JoeE. liked this post
  12. #8
    Nov 2007
    marysville ohio
    9,892
    2820
    6593
    Tried an earlier conventonal "diamond mesh" version. It sucked. Grabbed leaves and held them 'til they rotted.
    I would like to see a photo of yours. What is the brand name?
  13. #9
    Dec 2015
    Connecticut
    1,179
    27
    392
    I had the same stuff that Bill is describing at my old house. I bought it 25 years or more ago. Mine was actually called Gutter Helmet. The top of the gutter is completely covered and water flows along the top , to the front ,down a smooth ~3/4” diameter 180 degree curve (now under the gutter guard and above the gutter, where it hits a sharper 90 bend aiming straight down into the gutter.
    As Bill described, the leaves can’t make the 180 and fall to the ground. I seem to recall In real heavy rain, some water flowed off the front too, but better than a clogged gutter.
    Helmet Heat(R) Ice Reduction System: The Proven Ice Dam Solution | Gutter Helmet
  14. Likes JoeE. liked this post
  15. #10
    Dec 2012
    AUSTRALIA
    2,899
    12
    947
    The helmet wouldnt work here ,we get torrential rain,and it would just cascade over......nightly drip would be OK though.....never seen it local.Every gutter guard Ive tried with holes sucked,cause leaves got under ,and then couldnt be got out.....On the patent is good ,too,I was asking a local crowd about steel fencing,and why they couldnt supply the flat with ribs type....patented ,he says,we only got this roofing sheet type....,which is hard to erect.
  16. #11
    Virginia
    31,460
    7561
    9880
    Quote Originally Posted by moonlight machine View Post
    Simple principle, so there are several. Home Depot had the ones we are using.
    Start here, do your own due diligence, based on type of environment, trees & such where YOU live.
    Top Gutter Guards of 2020 | ConsumersAdvocate.org
    As to overflow in torrential rain?
    "BFD". "The wise" also have a drainage bed at ground level to divert SURFACE water away from foundations BEFORE it soaks down to the drain at the footer.
    Clean that with an ignorant leaf rake or leaf vacuum/shredder. I never saw the POINT is blowing leaves away... so they could just blow right back again.
    That's nothing more than a socially acceptable - if rudely noisy - form of public masturbation. Worse? Too-often "hired done".
    No fear.
    Looter-lie-bore-alls get elected, it will be "free", like everything else. At least until they run out of "OPM", about three weeks before they even start to re-allocate already-scarce ass-ettes.
    WTF? Nobody understands grocery-store 'rithmetic these instant-gratification ear-bud and free drug days?
    Darwin - and the Devil - must be getting ready to FEAST! Again.
  17. Likes moonlight machine liked this post
  18. #12
    Dec 2012
    Se Ma USA
    1,751
    140
    958
    The helmet works by laminar flow. The water will adhere to and flow around the curve quite a bit. It would take a huge flow for it to become free and go straight down. Even then plenty will still go in the gutter.
    I have an air float table on my beam saw and felt a jet of air on my hand under the edge of the table. I looked and no hole. After poking around I found the leak was a horizontal leak at the top plate and the air wrapped around the sheet metal and jetted straight down. Laminar flow.
  19. #13
    Oct 2005
    17,887
    BTDT guy spamming incessantly on craigslist, sells machines to roll form these:
    Page Not Found | Facebook
    Rutt Roh:
    Paul Zondlak
    What you NEED to know about Gutter Wizards
    It was a rollformer (truck mounted) for the solid "laminar" style gutter guard.
  20. #14
    Jul 2004
    Southeast Michigan
    6,687
    252
    1595
    generally when it comes down so hard it's overflowing past the gutters, it isn't because of momentum of the water, it's because you can't fit any more water in that 2x3 hole that 500 sq ft of roof has to drain through.
  21. Likes CarbideBob liked this post
  22. #15
    Apr 2004
    Modesto, CA USA
    7,523
    1319
    Recently at a big box store I saw a new style eleaf guard. It is slightly bowed stainless sheet similar shape to the op. It is pierced with very small holes down the middle 3/4 or so with solid edges. the holes are about 1/16" spaced every 1/4-3/8 inches.
    Bil lD.
    Similar to this one But I think it was al lone piece with folded edges.
    https://www.amazon.com/Raptor-Gutter...MCJ55BWHTMN11G
  23. #16
    Oct 2005
    17,887
    Quote Originally Posted by Scruffy887 View Post
    Like to see how it works on a steel roof at a 12:12 pitch.....
