adammil1
Titanium
- Mar 12, 2001
- New Haven, CT
It may be outside of the realm of what alot of you guys do but I am always suprised with the knowledge that I find on this site.
I am trying to instrument some previously designed gearbox test stands to meet my own test and measurement needs, and I am looking for something where I can hopefully place a contact type tachometer against a shaft and get highly accurate measurements of RPM with out modifying the test stand at all.
Typically speaking when we use tachometers in this line of work we use standard hall effect magnetic pickup sensors, where usually we have an existing gear on a shaft and each gear tooth that goes buy creates a electrical spike. Basically you have the gear functioning as an encoder wheel.
Unfortunately it is looking like it will be very difficult to modify a few of the test stands to put any type of gear on them, thus what I am wondering if anyone has heard of an off the shelf contact tachometer that can be mounted semipermanently against the shaft and output me hopefully a signal containing multiple pulses per revolution that I can record and use to monitor the gearbox.
What ever I would be using would have to be very accurate as in many cases I am trying to determine shaft speeds and gearmesh frequencies of that are several times higher than the shaft that I could measure speed from. Thus any error would quickly multiply.
I have done some searching on Google and yet all I seem to find are a bunch of these hand held combination tachometers that have a wheel on one end that look like this.
However I really need something more permanant and something that will also direct output its pulses to me. I am envisioning that there has to be someone who makes something that works similar to the old travadials that mount on a lathe carriage, where you just press this box with an encoder wheel hard against the shaft and then have a working tachometer. Has anyone ever seen such a thing or have an idea where to look for one?
I know some of the groups have printed out mylar sheets index lines and than wrap them around the shaft and use a reflective type optical encoder, but I would like to avoid that if at all possible, as they can be very prone to dirt and other problems.
Just wondering if anyone has ever seen such a thing?
Adam
Adam
