How to put a knife edge on a piece of 7075 aluminum?
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    Feb 2016
    Connecticut
    19
    7
    Default How to put a knife edge on a piece of 7075 aluminum?
    I have a piece of 7075 .100" thick aluminum approx 5" x 3", one end is curved and along the curve I need to have a bevel cut like a knife. I have tried to grind it down with my handheld grinder and smoothing it with a file. It does not look very good...looking for a better way to put this kind of edge on it...any ideas?
    My tools are mostly for woodworking but not limited. I don't have a mill or something to cut the edge..here is a picture of the curve I am talking about and also if you could give me some ideas on how to bend the piece to a smooth curve after I add the edge it would be helpful too
    Dec 2008
    Vt USA
    6,604
    714
    2231
    use a sharpening stone. submerged in kerosene or even soapy water.
  3. Likes Tozguy liked this post
    Feb 2006
    Indiana
    12,715
    635
    3680
    Carbide router bits or saw blades run at woodworking speed will cut aluminum and leave a smooth surface. You need to be very cautious in how you hold the metal and take very small cuts. Aluminum takes more power to cut than wood, hence the small cuts.
    Never use aluminum oxide abrasive to try to grind aluminum. Zirconia or silicon carbide will work OK.
    Larry
    Feb 2009
    Oz
    373
    16
    74
    Quote Originally Posted by L Vanice View Post
    <snip>
    Larry
    Yeah, but everyone does. They grab the angle grinder and hit the aluminium like it is steel. If you are doing this, make sure you keep the wheel clean and not not choked up. Drag an old masonry drill across the spinning wheel to clear the clogging regularly.
    The danger is the wheel can clog up, quickly go out of balance, then fly apart after vibrating like hell.
    Jun 2015
    CANADA
    British Columbia
    1,191
    263
    617
    I should think a large file should do it nicely.
  7. Likes Tozguy, allloutmx liked this post
  8. #6
    Nov 2015
    Oklahoma
    233
    49
    104
    Vixen files are made for stuff like that.
    1" Vixen File Single Cut
  9. Likes Winterfalke liked this post
  10. #7
    Apr 2007
    Melbourne Australia
    180
    28
    18
    That looks like a Turn Fin from an RC boat.
    I use a belt linisher to sharpen the leading edge. Only sharpen the outside edge.
    I see the initials TI at the top, pretty sure you have a Titanium fin there, Not 7075T6.
  11. #8
    Dec 2011
    Schwenksville, PA
    1,257
    705
    733
    Quote Originally Posted by Kenre View Post
    title of image is "turnfin".
  12. #9
    Feb 2016
    Connecticut
    19
    7
    Yes it is a turn fin for an rc boat. You'd be surprised how little people want to share about how they make these.
    The one in the picture is Titanium and one I currently have, but I want to make my own out of 7075. I need one with a slighly different shape/length
    I am leaning towards using my router (and table), not sure how I can hold it safely though.
    If I can make a nice edge on it, I will bring it to a shop so they can roll slip it to curve, but maybe I can do that myself too?
  13. #10
    Feb 2016
    Connecticut
    19
    7
    I would file it if it didn't take 3 hours to make perfect and kill my arms...
  14. #11
    Mar 2004
    Edison Washington USA
    10,232
    949
    5259
    I use brown grinding wheels for roughing aluminum, on a 4 1/2" grinder.
    Then, for finish, I use alumina zirconia flap discs- probably 100 grit or finer.
    brown wheels- from Rexcut- Rex-Cut Abrasives - Home
    most decent welding supply stores will stock these, or you can order direct, or, most likely, from MSC or McMasters.
    Lee Valley has em for six bucks
    4-1/2" x 7/8" Rex-Cut Max Flex Wheel | RC-4-1/2MF - Lehigh Valley Abrasives
    the flap discs I use are klingspor, but norton or pferd or sait all make good flap discs- blue, alumina zirconia is what you want, 100 or maybe 120 grit.
  15. Likes gusmadison liked this post
  16. #12
    Feb 2016
    Connecticut
    19
    7
    Very nice- I guess the right disc on my 4-1/2 will work great too
    I say that because I can get a pretty good edge with a black grinding disc, it's just a matter of cleaning it up with the right disc. And If I use a better disc for the first rough cuts, that will help later on to finish.
  17. #13
    Oct 2003
    East Peoria, IL, USA
    5,362
    329
    779
    It's not rolled I think. It's bent in a press with a die. You can make that sort of simple die yourself. you can use a belt sander to sharpen them pretty darn quickly.
  18. #14
    Jul 2006
    Arizona
    4,502
    18181
    4222
    Quote Originally Posted by aaronhl View Post
    You will need to anneal the 7075 if you want to bend it like the sample.
  19. #15
    Feb 2016
    Connecticut
    19
    7
    Interesting... How do you know it's bent in a press and not rolled?
    How can I make one of these or what is the name of it so I can search for it
    If I torch it and bend it, will the 7075 be the same strength again once cooled?
  20. #16
    May 2005
    Interior British Columbia
    2,209
    229
    669
    You have a table saw? Router? Use the saw to make an angle jig. Use the router to carve the bevel. Make a jig to fit in a bench vise or shop press to make the bend. Practice on some scrap and expect to make more than one version of the bend jig to get the curve the way you want it.
    If it takes you three hours to file it, you have the wrong files, Get a coarse double cut file for roughing out the bevel, A vixen file is probably overkill, but would work and with practice, would leave a pretty good finish too, a couple single cut files for finishing, like as not a Bastard and a Fine cut. Should take you all of about ten minutes to put a good bevel or bevels on the fin, then bend it. Secure your stock on the edge of the bench, and put your back into it. Take care of your files. Pick them clean if they get pinned (bunged up with filings and metal), and keep them from rattling against each other. Replace as required. The are cutting tools, they wear, get blunt, and generally deteriorate in use.
    Look into learning about draw filing.
    Wet or Dry paper wrapped around something solid and flat to finish. Use water with a drop or two of dish soap in it. I liked using offcuts of acrylic (Plexiglas) for flat sanding stuff. Start coarse, work your way up, it goes really quick.
    You can spot anneal the 7075 by drawing a line on it with a Sharpie Marker, and heating it with a torch until the line vanishes. Drop it in water to stop the process instantly. It's aluminum. Quenching it like that simply stops the anneal process, does not cause it to harden like steel does.
    By spot annealing, you still keep the temper up at the point it is connected to the boat. The area you want to bend will be soft.
    Cheers
    Trev
  21. #17
    Aug 2008
    Californeeeah
    1,481
    45
    314
    I've only seen fins for full-sized hydros, and they're always straight, adjustable angle mount. Seems like the curve would cause extra drag without doing any work. Is this common on RC boats?
  22. #18
    Jul 2007
    UNITED KINGDOM
    4,613
    2394
    2179
    With 7075 you should start by lapping it against strong sunlight and get the final edge by honing it on waning moonlight.
  23. Likes tdmidget liked this post
  24. #19
    Jul 2007
    Canada
    748
    50
    125
    Practice makes perfect. Also, it sounds like you're using the wrong file for the job. Get a coarse toothed file for roughing, only switch to the fine ones for the final clean-up. I have a big old curved tooth file that happily hogs aluminum and leaves a smooth finish.
  25. #20
    Apr 2007
    Melbourne Australia
    180
    28
    18
    No need to anneal it for that radius bend, it will spring back somewhat, so a little over bending will be required to get the correct shape.
    you can make a radiused bend with a couple of dies, one being a piece of round bar, the other something concave to press into. A press or large vice may even be enough. Hint, press the shape first, then cut to shape.
    Several bends close together will achieve the same thing as a constant curve.
    RC turnfins have the hook on the bottom, or an angle to stop them coming unhooked or riding up out of the water.
    Heres an example, Twin Engine Hydro - YouTube
  26. Likes neilho liked this post
