How to rReduce the taper size on a MT drill
Results 1 to 14 of 14
    Sep 2004
    Alabama
    566
    92
    Default How to rReduce the taper size on a MT drill
    I have lathes and drill press that have #3MT sockets, but some of the drills I want to use are #4MT. I have an adapter that will let me use them, but the adapter makes everything too long.
    If I had collets that would go up to 1-1/4" then I would put the bits in a collet and turn the #4MT down to a #3MT. However, all I have are 3 and 4 jawed chucks.
    Any proven techniques for turning these #4MT drills down to #3MT?
    Jul 2004
    Houston, TX USA
    29,638
    Worked for me in making them straight shank - would seem to work as good making taper smaller
    Assumes center in tanged end in good shape
    Put suitable stock in chuck
    Bore 1/8 to .200 deep same size as drill point
    Then bore under size about 1/2 deep
    Put drill point in bore
    Put center in tang
    Do what is wanted to taper
    Drill is driven by shoulder in bore - assuming one is not hogging away on taper
    And to respond to Gordon - not a hard one in the several I did this to - maybe I was lucky
    May 2010
    DENMARK
    3,248
    4016
    12701
    The tapers are different plus almost certainly hardened so I'm interested in hearing any advice you may get.
    Morse Taper (MT) Dimensions Chart | AutoDrill
    Aug 2009
    AUSTRALIA
    522
    108
    72
    All the drill shanks I have used were soft. Even some drill sleeves are soft. I think if you using a sleeve on a live center it should be hard for precision locating, but for drills soft so there’s some deformation to get a good grip.
    Someone told me they were friction welded together the main body and the shank. Even small twist drills can have soft shanks. It would depend on manufacturer.
    Dec 2014
    Washington
    201
    334
    84
    we turn a lot of drill shanks here. some come in soft as a millennials hands some are harder than a goats head. for the hard we use cbn for the soft regular carbide.
    Sep 2004
    Alabama
    566
    92
    I agree with BSCustoms, but the question is how do you hold the drill using only a 3 or 4 jaw chuck so that you can turn it?
    I believe John's method will work, but is there another way?
    Mar 2005
    Kansas
    7,429
    426
    3405
    I have several drills where a previous owner turned about 1" of the end straight so it could be held in a chuck. It can still be held with the taper.
    Jul 2011
    Brusly, LA
    726
    20
    291
    simply trade them to me for 3mt drills!!! PM sent
  9. Likes Rudd, jims liked this post
  10. #9
    Aug 2009
    AUSTRALIA
    522
    108
    72
    Quote Originally Posted by nt1953 View Post
    If your jaws are long enough they should bridge the flutes and grip the lands. With some packing and not over tight should be ok. Or use the tail stock and use packing on the jaws and grip the neck? Of the drill between the taper and the flutes where it’s parallel.
  11. #10
    Jul 2006
    Arizona
    4,587
    18413
    4305
    Just buy the MT3 drills you need on ebay. TONS of them on there for cheap.
    You need a 1-1/4" drill bit? Here you go (not mine just found on a search):
    NEW HSS 1-1/4'' #3 Morse Taper Shank Drill Bit, 13'' OAL x 3/4'' Shank | eBay
  12. #11
    Dec 2014
    Washington
    201
    334
    84
    We make a split bushing of aluminum to grab on the lands of the drill.
  13. #12
    Langley, B.C.
    1,661
    335
    970
    Quote Originally Posted by Philabuster View Post
    ...Just buy the MT3 drills you need on ebay. TONS of them on there for cheap...
    My thoughts exactly. I can't imagine wasting time turning down the shanks of a bunch of drills. You can
    go to all that trouble and if you don't get them damn near perfect they won't hold worth a damn anyway...
  14. #13
    Sep 2004
    Alabama
    566
    92
    I am trying John's method and so far it appears to be working OK. I will post more when I have made the tangs on the ends of the drills and can try them out.
    I have looked for MT3 drills over 1-1/4" on eBay and while there are a few, there are not many, and those that I have found are priced too high for me.
  15. #14
    Aug 2006
    N.W. Ark.
    403
    238
    68
    Just got off e bay looking for motorized work head and everything is priced TOO high...
    many moons ago i made a live center with a female 60* center. what i used to do was put center in head stock, put drilling end in tail stock with modified live center and if you want to make 3 MT get indicator to read 0 length of taper then take drill you want to convert install in lathe and cut away til you get the size you want..
