conceptdevelopers
Cast Iron
- Jun 16, 2007
- Garland TX
I do the solid modeling and programming. We cut a lot of 2024, 6061 and 7050. I'm having a disagreement with co-workers on how to stop parts from bowing or twisting. I think the solution is done with multiple solutions.
1.) If we can, normalize it before starting
2.) use SFM and depths of cut recommended by cutter manufacture
3.) If we have access stock take skim cuts on the cold rolled material and straighten that before it's cut.
Machinist in the shop tell me to take light cuts and cutting slow will result in straighter parts. I said it is heat that is one of the culprits and the cutting it slow doesn't help but hurt.
I'm looking for a solution not a need to be right
What say you?
What say you?
