How to trim abrasive cut-off wheel
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Jul 2006
    rochester, ny
    1,831
    365
    509
    Default How to trim abrasive cut-off wheel
    Broke a little piece off the wheel I use on a chop saw to cut HSS shaper knife stock. Doesn't seem like a good idea to use it as is, wondering how to make it round again?
    It was a pretty pricey wheel, $50, cut really fast, prefer not to have to replace it.
    It's not reinforced (dope slap!)
    May 2011
    New Jersey
    1,613
    153
    846
    A garbage can...there's no real safe way to do it.
    Jun 2012
    Michigan
    9,274
    3155
    3333
    You can dress with a silicon carbide carborundum stone, use a roller abrasive dresser like a cracker jack mini or just use it with a careful infeed to the part.
    Problem is the you can’t ring test such a wheel so all methods are dangerous. But the last method the least dangers.
    I would box it in as best I could with not much big effort, perhaps put on an old jacket, wear gloves and face protection and carefully feed it into a cut off part.
    On a surface grinder would only feed on the grind side/not the climb side.
    I have done such and found a new wheel out of the box is as likely to blow as a chipped wheel.
    Yes fire it up and let it spin for a minuet or half before using. *I would use it but take no responsibility for your using it.*
    Handling such wheels is tricky. I like to keep them on a wood stub wall hanging with a thin (1/4") plywood cover sheet.
    Wheels are difficult to hold-the-wheel for tightening so a way to hold fast the spindle is best.
    Nov 2007
    marysville ohio
    9,011
    2565
    5969
    Quote Originally Posted by plastikdreams View Post
    You are going to repair then stand in front of it at 3000+ rpm.....yeah good plan. 50.00 wheel........Thousands at the hospital, hmmmm. seems like a no brainer to me.
    Jun 2012
    Michigan
    9,274
    3155
    3333
    Two out of three say scrap it ..so I guess they win.
  6. Likes woodchuckNJ, MetalCarnage liked this post
    Mar 2009
    Eureka, CA
    3,617
    689
    1189
    Richard,
    Don't have any insight into your current problem but I'll say this...I have cut bazillions of moulder knives in D2-HCHC using a chop saw with a run of the mill abrasive wheel and it works great. Unless your HSS is a whole bunch tougher than D2, maybe give the abrasive wheel a try.
    Stuart
    https://www.amazon.com/Metal-Abrasiv.../dp/B0070OJS7K
    Apr 2011
    AUSTRALIA
    105
    31
    37
    On a weekend with all shops shut, I had a similar problem a few years back with a thin surface grinder wheel.
    I put the wheel on a slow speed grinder with a quick and dirty arbor spacer, I stood well aside and dressed it gently at 790rpm. Once the diameter was below the broken bit, I put it on the surface grinder and dressed it true - gently and carefully. It was fine after that.
    Mind you, I never trusted it and I wouldn't do it when the shops are open or the job wasn't in a rush....
  9. #8
    Sep 2010
    Oklahoma City, OK
    3,845
    668
    1673
    Im my younger years I'd have just pressed on with it.
    Sent from my SM-G930R4 using Tapatalk
  10. Likes Rob F. liked this post
  11. #9
    Nov 2018
    CANADA
    British Columbia
    153
    27
    102
    I routinely repair chipped and cut to smaller size abrasive wheels and grinding stones on wterjet cutter. On thin abrasive cutoff wheels takes a minute or less to cut a new circle. I use the centre of the wheel as referance point for the waterjet cut and then true the wheel(s) with diamond. Even if you do not have a waterjet cutter, taking it to a shop that has is usually less than the cost of new, or special size, wheel.
  12. #10
    Aug 2012
    California, Central Coast
    2,700
    2078
    972
    Used to be we would break chunks out of the chop saw blades with pliers to cut hard material. seemed to slow them glazing up. If saw has a guard I would run it, just stand to the side.
    You could also use an angle grinder to "dress" it.
  13. #11
    Aug 2014
    bainbridge island
    1,044
    196
    252
    for what its worth an 8" aluminum oxide grinding wheel at 3600 rpm scares me. you've got a 14" wheel rated for 3800 rpm. that's equivalent to 29,700 rpm for a 5" angle grinder, mine runs not even half that speed, or 1/4th the centrifugal "hoop" stress that disk is rated for.
    if you're using that disk at 1750 rpm, i would continue to use it. and if you're worried about it blowing up then you need to quit thinking that an undamaged disk won't blow up.
  14. #12
    May 2017
    FINLAND
    1,503
    432
    692
    Quote Originally Posted by Rob F. View Post
    I wouldn't run any sort of disk in a chop saw without guards, broken or not.
    Diamond wheel on a angle grinder would cut the excess off in a haste. Either "dress" or carefully slice from the side while spinning the chop saw by hand.
  15. #13
    Jul 2006
    Hillsboro, New Hampshire
    6,243
    1486
    4357
    Try some of these, or a similar reinforced wheel: https://www.amazon.com/IVY-Classic-4...ustomerReviews
    $13, not likely to fail like your unreinforced wheel did, get a few other brands while you're at it to do comparisons. Ditch the broken wheel, or place it on a hook with a note saying "This is why you don't buy unreinforced chop saw wheels".
  16. #14
    Sep 2015
    Tennessee
    454
    234
    349
    Quote Originally Posted by Wlodek View Post
    The problem with that is there could be a crack you don't see all the way to the arbor hole. I had a friend who lost an eye to a wheel that let go after it was damaged.
  17. #15
    Oct 2005
    13,471
    Angle grinder and no need to spin the cut off wheel fast....just rotate it against the angle grinder.
  18. #16
    Jun 2012
    Michigan
    9,274
    3155
    3333
    I would by hand notch an aluminum oxide wheel with notches about an inch apart but nicely spaced and perhaps 1/4" deep using a cut off wheel . This to make the wheel act a couple letters softer for surface grinder work. SG are safer than OD, cylindrical and TC grinders because the SG wheel faces a safer direction.
    I often used a a heavy sheet metal 10" x 14" (perhaps 12 gauge)that I would place between me and the work on a SG or TC grinder, Mostly to control the dust and coolant but it also to gave me some more protection.
    We had a cut off wheel set up on a Cincinnati #1 TC grinder with having a compound angle vise, With that we would do simple cut off chops and angular cuts to rough cut most any odd angle to rough shape cutting tools and steel parts going to a milling operation. That method saved many hours. Coming into parts at angle took a some care needing a very slow in feed to get a start in the part, some times needing a little cross feed so the wheel would get straighter for the plunge.
    Cant remember notching a cut off wheel but likely would have done that if I felt the need, likely would use a diamond wheel for that notching.
    Still it is not good to tell others to do odd things on grinders. Guys who grew up with senior grinder hands learn methods to do such things in a safer way..That is not for the new guy or guys who might not know or be willing to do the drill every time. Dumb things can get someone killed...like leaving the T wrench in a chuck or putting a wheel on a spindle with not dressing it, some guys just cant/wont do the drill.
  19. #17
    Sep 2010
    Oklahoma City, OK
    3,845
    668
    1673
    Yup, the welder's helper would gash the wheels.
  20. #18
    Jul 2006
    rochester, ny
    1,831
    365
    509
    Thanks for the replies, not surprised many suggest just replacing it. I broke that little piece off by trying to pick it up holding it there, not realizing it wasn't reinforced. The machine is full guarded, and I wear a face mask when I use it, so still tempted to trim it back. I use it very infrequently these days.
    I bought the wheel from C.G.G. Schmidt Co, the outfit that makes woodworking knives and cutter heads, they sell it specifically for cutting hss knife stock. It cut like butter, WAY faster than all the other cut off wheels I tried, and with no heat, well worth the cost.
  21. #19
    Jun 2012
    Michigan
    9,274
    3155
    3333
    QT[ still tempted to trim it back.]
    Using it carefully is the safest way to trim it back.
    if you are worried.. is there any way you can stand well out of harms way and from there slow feed into a cut off operation..
    what are you using it on..perhaps a large chop saw like machine..
    Agree such a wheel is often way better than a reinforced wheel.
    It is good to wear a dust mask for any abrasive grinding.. even heavy sanding by hand.
  22. #20
    May 2006
    Seattle
    1,789
    33
    324
    Many years ago I worked at a place that build prefab metal buildings which went on barges to Alaska. They had a 20" abrasive saw. I busted a little smiley into it the same as you did. I young and scared of losing my job and I just kept cutting with the same blade. After cutting parts for a few minutes, smiley was all gone. I'm still here.
    I vote for keep on using it. Cutoff wheels are not like surface grinding wheels. Cutoff wheels are reinforced to keep them from cracking and coming apart.
    Just my opinion, worth exactly what you paid for it. If you follow my advice and kill yourself, please don't complain to me! :-)
    metalmagpie
  23. Likes michiganbuck liked this post
