Yes and the bearing a pain. The milling cutters using it were more popular but would turn out to be not so economical in use.
Remember the ones for milling, had a single insert in a full-round body, the inserts were laid way over and sharpened oddly, positive rake ? Those used to work super for finishing. But they didn't spin, just clamped down solid.
RNMG not a good AL insert on a lathe unless you have big parts, big machine, heavy feed rate and high pressure coolant.
Agree with everything you say (except don't need high pressure coolant) but when faced with a part like this
they worked pretty well for roughing out the center section. Needle in the red and chips everywhere. I love the howl of a motor working hard
Yeah you can plunge in at an angle, use left and rights, blend the bump at the bottom where they meet but ... a 1/2" round with a brawndo lathe was faster and worked (I think) better. Cut in both directions, plunge go plunge go plunge go, fast. If you want to get fancy you can arc-plunge, which helps a tad with the chatter when you change directions.
Finished with a 6mm positive rake round on an extended holder, just a light fast skim cut across the entire surface, came out nice except you're right, that bastard
really wanted to chatter.
Still think it's the best way to make that part tho. Either that or forgings
