Hi all,
I'm struggling with how to proceed on a repair to this automotive electric cooling fan. (bearing replacement).
The fan itself is molded plastic, and has a steel sleeve embedded into it.
The motor shaft passes through the front housing & bearing, then is press fit into this sleeve.
I need to press the shaft out of the fan, but can't figure out any good way to support the motor side, except on the plastic ring outside the motor housing. I'm concerned that it'll deform or crack the plastic fan before the shaft comes out though.
If I try and press the front housing against the fan, it doesn't want to sit flat, and rocks slightly.
Totally get that this is meant to be a non-serviceable part. It's horrifically expensive to replace so I'd like to at least try - the bearings seem to be a standard size.
I have access to a small lathe/mill, a press, various pullers and standard mechanic's tools.
Thanks very much for any ideas or suggestions.
I've tried to draw out the problem, and attached a couple of photos:
Approximate drawing:
rear of fan motor unit
face of fan showing shaft and sleeve
