how would you run 220/3 phase to power an oddball 340v 3ph machine?
Likes Likes:  0
Results 1 to 6 of 6
    Jul 2004
    N. GA- 33.992N , -83.72W usa
    4,069
    112
    976
    Default how would you run 220/3 phase to power an oddball 340v 3ph machine?
    i looked around an only saw 120/220/440 . what about vfd's .. at different
    freq and voltage? i have plenty of current @220/3 , but am unsure how i
    would power a 340v (probably 50hz) weirdo- euro mill.
    maybe not so much the spindle as what is happening behind the scenes- power
    feeds , contactors, pumps, excedrin...
    Jul 2007
    UNITED KINGDOM
    5,471
    3425
    2820
    Cheapest way would probably be three 220-110 transformers wired as autotransformers (=330V) and connected to give the three phases.
    Jan 2005
    Houston
    7,055
    1295
    4031
    How much HP?
    Three transformers would be pretty bulky and costly and probably give some phase imbalance.
    A VFD would do well, if you otherwise want a VFD on this service.
    Dec 2008
    Vt USA
    9,234
    1611
    3315
    Quote Originally Posted by GregSY View Post
    How much HP?
    A 440V VFD supplied by the same can easily be programmed to output the correct V/H curve to match that motor.
    As long as the curve intersects at the 330/50 point, added V at higher frequencies will work fine, and provide full power at over speed!
    Seems perfect to me, and just needs a 240/440 transformer and a VFD to match.
    (I happen to have both units that could be made redundant in my shop if interested ;-)
    Jul 2004
    4,069
    112
    976
    8kw @ rated . but that's subjective.
    Jul 2007
    UNITED KINGDOM
    5,471
    3425
    2820
    Three transformers will give no more phase imbalance than a three phase tranny. A 340 (should it be 380? that would be more common) Volt VFD will need a comensurate input voltage-> Back to square one! A three phase transformer would be more compact, but not neccessarily more economic or available.
    Don't worry about running a 50Hz machine on 60hz. yes, it will run 20% faster, but that won't hurt anything unless it's a clock.
