Huge Air Compressors
Page 1 of 2 12 LastLast
Results 1 to 20 of 37
    Jun 2009
    Michigan, USA
    2,183
    3306
    1719
    Default Huge Air Compressors
    What is the largest air compressor that you have ever seen?
    I worked at a General Motors plant that was about 40 acres under one roof. It was highly automated and had tons of pneumatics as well as a lot of air blowoffs and other air hogging operations.
    The entire plant was run by one air compressor. It was locked in a cage and you couldn't get real close to it, maybe five feet away at the closest. Brand name was Centac. The armature on the motor was around 6 feet in diameter. As I recall the motor was 4,500 HP and it ran on 7,000 volts of power. (we had our own power plant) It was a four stage turbine compressor and as I recall the largest impeller was around 3 or 4 feet.
    Our plant had about three other compressor rooms filled with big old Worthington piston compressors but they rarely ran in the 30 years that I worked there.
    In all the time that I worked there I only recall seeing it not running one time when it was down for a rebuild. I worked a lot of nights and weekends, holidays, you name it and I was there. I'd ride by on a scooter and the whole plant was shut down but that motor was still spinning.
    I've always been kind of fascinated by huge machinery and this was no exception. It got me to wondering if there are larger compressors out there.
    Feel free to share your huge compressor story here.
  2. Likes JoeE. liked this post
  3. #2
    Jul 2013
    Indiana
    3,204
    4695
    1620
    I've been here 21 years and it never occurred to seek out where the air compressor is or how big it is. I went around to the back of our plant and seen an engineer, ask where the hell was our compressor. He pointed at this and said it was our old one. The third picture down I believe has something to do with the dryer. Also a holding tank out on the floor by some Die Cast machines.
    Brent
  4. Likes JoeE. liked this post
  5. #3
    Mar 2009
    Eureka, CA
    3,725
    736
    1276
    A dinker compared to the one you note, but formidable anyway. Worthington Air Compressor Links
    One just like this provided air to the sawmill I worked at in Eureka, CA.
    Slow-mo for sure but with a terrific CFM rating.
    Stuart
  6. Likes JoeE. liked this post
  7. #4
    Jan 2005
    Houston
    5,572
    488
    2378
    As far as piston-type compressors, here's a big one. 23,000HP 200RPM
    If you include centrifugals (like a Centac would be) then you can get up in the 100,000HP+ sizes.nova.jpg
  8. Likes JoeE. liked this post
  9. #5
    Aug 2005
    Toronto
    4,768
    3191
    3621
    I've a 750 CFM and felt strong. Now I feel inadequate.
  10. #6
    Dec 2012
    AUSTRALIA
    2,017
    9
    619
    I bought a big Bellis and Morecambe once for scrap......when it was running,it was almost silent ,but the concrete floor moved.....it was twin cylinder upright ,double acting,like a big upright steam engine,driven by a 1250HP synchronous motor at 250 rpm.B&M did also make steam engines on the same design...Estimated around 5-6000 cfm at 150 psi.
  11. #7
    Nov 2014
    Florida
    3,662
    1522
    1738
    Quote Originally Posted by yardbird View Post
    Brent
    You have been machining at one place for 21 years??
  12. #8
    Apr 2005
    Beaverdam, Virginia
    7,360
    655
    3469
    That length of time would get me something like 8 jobs working for the man and 5 years self employment.
  13. Likes adama liked this post
  14. #9
    Nov 2004
    Webster Groves, MO
    7,221
    1813
    3282
    [QUOTE=Big B;3358800]
    /QUOTE]
    Probably because the power co. hit them with some outrageous peak charge when they started it. Cheaper to let it run.
    Bill
  15. #10
    Jul 2013
    Indiana
    3,204
    4695
    1620
    Yes Sir I have. Unless I keel over I'm gonna do nine more that'd be 30 and out at 59. If I've got a big enough pile that is? Doubt it? Lol...
    Brent
  16. Likes JoeE. liked this post
  17. #11
    Jan 2019
    Tennessee
    457
    140
    120
    ours feel so cute now. 2x 50hp screws and a 25 screw back-up (original to original shop building I understand)
  18. #12
    Jun 2009
    Michigan, USA
    2,183
    3306
    1719
    Brent
    I did a little bit over 30 years and retired at 49. Haven't looked back either.
  19. #13
    May 2017
    FINLAND
    1,693
    480
    784
    Quote Originally Posted by GregSY View Post
    Didn't know that they make even piston compressors in that power range.
    Largest one I have seen is 12MW (16 000hp) centrifugal at local steel mill.
    Saturn V/Rocketdyne F1 turbopump is pretty big "compressor" (55 000hp) considering that its only used to feeding the fuel and liquid oxygen to the combustion chamber. And there is 5 of them in Saturn V.
  20. Likes JoeE. liked this post
  21. #14
    ga,usa
    159
    142
    55
    Sulzer has some big compressors. When I worked for Sulzer in South Africa our sales engineer said you could tell who ran the business by the compressors - Engineers = Sulzer. Expensive upfront, cheap to run. Accountants - Ingersoll-Rand. Cheap to buy, expensive to run.
  22. #15
    Jul 2004
    Houston, TX USA
    29,664
    Not much psi, but fantastic volume. Blast Furnace BLOWING ENGINES - in multiples
  23. #16
    Oct 2005
    14,909
    "That motor was still spinning" because it was probably a synchronous motor, with a PF correction of 1.0, look at the nameplate, others are .80.
    The run them to fix the Power factor.
  24. Likes TDegenhart liked this post
  25. #17
    Oct 2010
    Dewees Texas
    2,335
    27
    629
    I helped pull a cold tower up the hill in front of our place. The destination was somewhere out in west Texas. I understand a huge air compressor would have been paired with this tower to separate gases form the air.
    Would have been interesting to see the final installation.
    The tower by it self weighed 291,000 LBS. Did not see the compressor go by but a companion cold tower went by later, it was a little lighter and did not need assistance.
  26. Likes Garwood, yardbird liked this post
  27. #18
    Oct 2009
    Oregon
    4,145
    4446
    2098
    Quote Originally Posted by FredC View Post
    That is a great picture!
  28. #19
    May 2003
    Lambertville, MI USA
    2,548
    1070
    1124
    Quote Originally Posted by Big B View Post
    Did you work at Willow Run?
  29. #20
    Oct 2014
    Maine
    831
    85
    393
    The University of Sussex engineering department hooked the output shaft of a Rolls Royce Dart turboprop to the compressor from another Rolls jet engine (maybe another Dart, I don't recall). 10kg/s at 4 bar, which the internet tells me is 17,637 SCFM
